2008 yukon build.....Err uh mod thread
Old Aug 12, 2016 | 05:14 PM
  #301
About20ninj45's Avatar
Of course I'm following this... This shitis sick. I get ideas and wonder if anyone's done it, and then I see you have... So I'm like, shiiiiiiit I'll let him take the lead. You already worked out problems I didn't even think about. So I'm excited to see this finished.
Old Aug 12, 2016 | 07:12 PM
  #302
Wolftrk99's Avatar
Speaking of problems..... Need do some research this weekend, my truck, the denali/escalade harbess and the 14 yukon harness all have differnt connectors that go under the fuse box and connect two parts of harness togeyher i need to figure out what differnces are and which one i need to use.... Biggest issue is all three are different colors and sizes and wired differently... Unless i need to find a tahoe or yukon harness... Time to break out the computer and start digging through diagrams....
Old Aug 12, 2016 | 07:34 PM
  #303
I'll see what I can find out on my end. Which one are you trying to use? I also sent you a pm that you ain't respond to lol
Old Aug 12, 2016 | 09:55 PM
  #304
Wolftrk99's Avatar
The connectornon the right is the one in question.... I have not disconnected mine yet, but i want to find out what runs through it before i do.... And need find a harness that is compatible with it...
Old Aug 12, 2016 | 10:20 PM
  #305
1FastBrick's Avatar
Custm2500's Rude Friend
What are we up too now?
no wonder its not finished...
Old Aug 12, 2016 | 10:34 PM
  #306
Wolftrk99's Avatar
Getting last piece of puzzle squared away.... Details bro, details.... Rather be hung up on figuring this out now than in middle of running harness and figuring it out then....
Old Aug 12, 2016 | 10:42 PM
  #307
1FastBrick's Avatar
On a side note, have you ever seen a 6.2L engine with 24x reluctor wheel from the factory?
Old Aug 12, 2016 | 10:56 PM
  #308
Wolftrk99's Avatar
Thought i had seen something about one of the gm crate engines being available with 24x reluctor, but hadnt actually seen a production oe installed 24x in a 6.2...
Old Aug 13, 2016 | 09:27 PM
  #309
Wolftrk99's Avatar
So far i have found some information on the connector, it is x109 and there are apparently 2 different ones so for whether option code nqh transfer case or not....
Old Aug 13, 2016 | 10:13 PM
  #310
Wolftrk99's Avatar
So after some more research, the biggest difference i am seeing if that my 08 has the ac low pressure signal going to this connector, but the 09 amd up dont, so i am going to have to check terminal c12 and see if infact there is a wire there... If there is it would be nothing to add wire and tie the other side to ground, so not that big of an issue!!!
