2001 Frame up build
Old Jan 21, 2008 | 01:06 PM
  #231
BlackGMC's Avatar
Resident Retard
I read an article awhile back that said POR-15 and Rust Encapsulator actually work better and adhere better if there is a little rust on the metal... Because both products actually adhere to rust, they are designed to be put on top of rust and prevent it from spreading... If the metal is bare and rust free, a good self-etching primer is a good thing to use....
Old Jan 21, 2008 | 01:13 PM
  #232
moregrip's Avatar
what a rush!
good info! excllent work!
Old Jan 21, 2008 | 01:34 PM
  #233
1FastBrick's Avatar
Custm2500's Rude Friend
Originally Posted by GMracer
I remember reading about it, I'll have to check again. I used 80 then 180 on my frame but could always scuff it back up.
Just curious thats all. The product I use says you can use 80 or 150 grit but I have had better adhesion on a DA with 80 grit How ever I have never expermented with different types of sanding methods... Some Da's have a wider pattern and are more agressive while others are finer for doing that finish work. I am curious to see if I used a soft pad on a 7/9 inch grinder with 150 or a even on a long board how it would fair up. also i should test the diffrence between a close pattern DA and a more agressive wider pattern DA.
For those of you who are not sure what i am talking about DA's have a ratted swirl pattern wich I believe are usually 3/16, 1/8, and 3/8
Let me know what you find out about your product...
Thanks
Old Jan 21, 2008 | 01:55 PM
  #234
I will, and BlackGMC my frame is pretty rust free yet there are some areas that still have minimal spot rusts... so I was thinking maybe it'd be better to be safe than sorry... I guess I could ask Eastwood before I order because I do have two quarts of there primer sitting in my garage.
Old Jan 21, 2008 | 02:03 PM
  #235
BlackGMC's Avatar
Resident Retard
Hey man I am no expert by any means I was just merely stating what I have read. OH and please don't take my responses as critisim or anything. I think your doing a great job, I am just stating my opinions on what I would do in your situation... I have done about 5 restorations on various muscle cars over the years in various rates of decay and I have tried a bunch of different combinations, I am just stating from my experiences and results......
Old Jan 21, 2008 | 03:25 PM
  #236
midnight_bowtie's Avatar
Thumbs up
WOW how did i jus find this thread...frame is looking amazing man, cant wait to see the finished product. keep up the good work
Old Jan 21, 2008 | 03:32 PM
  #237
I take it as just how you say no worries, I'm glad you are helping me out.
Old Jan 23, 2008 | 11:12 PM
  #238
$thatguy$'s Avatar
its looking great buddy! keep up the good work!
Old Jan 26, 2008 | 03:57 PM
  #239
8ALTNG's Avatar
So when will it be rollin??
Old Jan 26, 2008 | 08:29 PM
  #240
Well I plan for August, but I'm thinking it will near completion next winter due to the amount of detail things going into this thing, including a one off front end.
For today, more tomorrow
So I needed a change from the frame work and cleaned up my personal garage today, then figured I might as well do somethhhhinggg to the truck. Took apart the heater box to see if I could remove the AC unit since I don't need it
All apart
Here is the other side with the useless AC crap haha. the bigger thing is the AC one
Cabin air filters were GONE!!!!! and talk about dirty inside
Also picked up this little gem from my moms boyfriend
Random shot of some shelves I hung for my detailing stuff
