2000 Silverado RCSB 2WD LS6 4l80 SWAP/BUILD
Old 12-21-2021, 03:00 PM
  #31
LS6RCSB's Avatar
Originally Posted by shakenfake
Shoulda done full ARP bolts
if I did it again I probably would, this was in attempt from the start to give it a 100% stock look under the hood. I did utilize arp for my head studs, and bottom end assembly.
Old 12-21-2021, 04:06 PM
  #32
arthursc2's Avatar
Received 1,438 Likes on 1,064 Posts
I did blow off a stretch belt on my G8, which was interesting because that car was stock and not really abused
The Tahoe, that is modified and abused somewhat (~6800 wot with a blower) never popped a stretch belt
Oh well, if it works, it works! Carry on!
ARP headbolts are the shiiiiiiiit. Love them
Old 12-22-2022, 09:04 PM
  #33
LS6RCSB's Avatar
Default Update
Finally found the time to get this truck back together after finishing up my IH (which will be tore back down mid March) Everything is going smooth. Well besides my caspers knock/crank sensor harness that is short 2-3” On the home stretch here next is the fuel pump, ended up going with a dw400, and going to put it in my stock sending unit, I’ll take some photos on how that goes!
The following 2 users liked this post by LS6RCSB:
Jeff71 (12-28-2022), strutaeng (12-22-2022)
Old 12-23-2022, 12:23 AM
  #34
DuNnO
RDF1's Avatar
Are you running a lingenfelter 58x/24x converter box?
Old 12-27-2022, 07:48 PM
  #35
LS6RCSB's Avatar
Nope, welded a 24x reluctor wheel on the stock 6.2 crankshaft
Old 01-05-2023, 04:05 PM
  #36
LS6RCSB's Avatar
Default Update
In the home stretch here, hopefully firing it up by the Sunday, I got the 415 dw pump fitted. Just some small odds and ends left. My j and l oil separator just arrived as well seems like a quality piece
Little dusty
The following 4 users liked this post by LS6RCSB:
ALL ULL C (01-05-2023), Jeff71 (01-06-2023), strutaeng (01-05-2023), zz454Chevelle67 (01-06-2023)
Old 01-10-2023, 10:40 AM
  #37
LS6RCSB's Avatar
Default Update
Home stretch... Finished getting everything together, even the whole a/c system. Just waiting for my new intake to come in so I can take the spectre off. Has power to everything, all fluids full. Does start for a moment and has oil pressure! Just waiting on my tuner for a base line for break in, then he can dyno and we’ll see if my 500whp is going to happen
The following 6 users liked this post by LS6RCSB:
adriver (01-10-2023), ALL ULL C (01-10-2023), Jeff71 (01-10-2023), R_D_3 (01-21-2023), strutaeng (01-10-2023), zz454Chevelle67 (01-12-2023) and 1 others liked this post. (Show less...)
Old 01-13-2023, 05:52 AM
  #38
smokinlmm's Avatar
Burn out time!
strutaeng (01-13-2023)
JMF05LS
02-08-2022 02:10 PM
SPDASND
12-15-2021 09:24 PM
j13alonso
02-09-2019 06:39 PM
SuperSporttruck
06-20-2004 03:07 AM
Quick Reply: 2000 Silverado RCSB 2WD LS6 4l80 SWAP/BUILD
