2000 silverado rclb to rcsb drag truck low budget conversion
Old May 20, 2012 | 09:49 PM
  #241
CAGRacing's Avatar
Old May 20, 2012 | 09:53 PM
  #242
slamdlsx's Avatar
2 link?
Old May 20, 2012 | 09:56 PM
  #243
BlackGMC's Avatar
Resident Retard
You went to all that work and left the shocks in the stock location??? Why?? Not to mention the angle of them looks insane. You should have relocated to the back of the rear end at 0*.
Old May 20, 2012 | 10:02 PM
  #244
CAGRacing's Avatar
I left them there for lateral location
2 link
I want the motor done for the upcoming car show June 16 so I have to switch priorities temporarily
The 2 link system is now completely stable and doesn't have any of the weird quirks once I added shocks and addressed the frame flex I was encountering.
Old May 20, 2012 | 10:04 PM
  #245
Atomic's Avatar
I have a gauge for that
The shock bushings completely negate any lateral support. For instance, unbolt a shock and see how far you can move it side to side. Any is way too much because while driving youll easily have 2000pounds of force trying to force it side ways.
Old May 20, 2012 | 10:08 PM
  #246
CAGRacing's Avatar
Its far from perfect
Pan hard will be installed soon. now that the truck changed so much by just adding shocks I'm wondering if this 2 link doesn't have potential
Old May 20, 2012 | 10:36 PM
  #247
UnVmy5.3's Avatar
well thats a big plus than before
Old May 20, 2012 | 11:21 PM
  #248
custm2500's Avatar
Ph.D. in HUBRIS
Looks much nicer now but like others have said it needs some attention. A pan hard bar is the main thing that should be on there before you drive it more then 3 feet in the driveway.
How do you have the back half attached to the factory frame? That 2"(?) tube is pretty strong but with the spring so far from the back half I would think some more strength should be built into it. If you notice back half kits usually have a 2x3 or bigger frame not 2" square. Now if you have a cage going in the truck the 2" tube might be enough to support the coil overs and the current springs but I don't think I would put my faith in that fairly light duty frame too long. You are going to tweak the currently nice looking product and be back to square one. Maybe I am wrong but I think you need to get some more steel back there to support what you have going on right now.
Again you got some damn good looking stuff going on now but I think you need to build in some more strength. Especialy since plan to put a fire breathing 1,000,000 hp engine.
Old May 21, 2012 | 12:22 PM
  #249
CAGRacing's Avatar
The kick up behind the cab is cut at an angle
The 2" is slid inside the c channel and welded everywhere it meets the frame
Above that where it levels off there's 1/8" plate reinforcing the corner
The coil springs now have upper and lower buckets
Pan hard will be fabbed up shortly.
Old May 21, 2012 | 12:37 PM
  #250
BlackGMC's Avatar
Resident Retard
what gauge thickness is that square tubing?
