1932 Ford pro street....re-build
Old May 17, 2013 | 10:52 PM
  #61
sprayed99's Avatar
Not much of an update other than a quick current engine pic and a few other small updates. I'm cleaning out the back shop at my friends shop and it will be going there soon to get cracking on finishing it.
I however do have a pile of parts building:
A 80LB box of polished stainless fasteners most are ARP
unisteer cross steer and all supporting steering parts
Vintage air mini evap box
Vintage air condensor
Vintage control panel
Lokar cable shifter (already test fit)
Polished Sanden SD7 compressor
Billet specialties A/C Vents
Billet specialties street rod throttle and brake pedal
New drive shaft
all the parts to build 1 7/8 primary to 3" collector headers from SPD
New King Bee headlights
assorted fittings and 3003 1/8" sheet to build fuel system
Quick pics. You can see the start of the PCV system that is all stainless hardline. I made the pcv to an adapter on the lathe last week. Also the stainless hardline coolant steam cross over system I bent up. I promise I will be updating with progress soon.
Also wanted to show what I did to remove the engraving from the Abear covers I got. I used a 1 inch end mill and cut out the "SUPERCHARGED 2004 PONTIAC GTO" and used 304 stainless mess to back it. This also solves the possible heat issue with the coils that some say was a problem.
Old May 17, 2013 | 11:00 PM
  #62
ak2007r6's Avatar
Looking good. Those covers turned out really nice
Old May 17, 2013 | 11:11 PM
  #63
sprayed99's Avatar
Thanks. Still need to have them gone over for a final polish. I will have that done when I drop off the Alternator, Intake, Alternator Bracket, and A/C Bracket (not done making) to the polisher.
Still thinking of using a chunk of 3/8th plate I have to make a aluminum trans pan for ***** and grins.
Old May 18, 2013 | 05:26 AM
  #64
rjwz28's Avatar
Man Motor club
Originally Posted by sprayed99
Back from the grave...
I revisted the alternator and said the hell with it and made a mock up and after a sort time I milled this.... Should work much better.
I also scored a set of Abear Valve covers that should be here next week.
Next I'm bending up stainless hardline to run the steam vent into the waterpump. After that is done I should be able to get the wiring done.....I hope.
Holy ****, I completely forgot about this thread! Nice solution on the alternator, looks great
Old May 21, 2013 | 11:59 PM
  #65
sprayed99's Avatar
Pics of parts
1 7/8th to 3" collector header parts... Yes I will be building the headers too
Billet Specialties Throttle and Brake Pedals
Billet Specialties A/C vents
Vintage Air Heat/Cool Mini Evap unit with vertical controls and 28-32 ford condensor
Billet Specialties Polished SD-7
Box of ARP bolts, polished button heads, fuel fittings, and misc other small parts
Ash bought these as a surprise. Lokar billet interior handles
Old May 22, 2013 | 08:03 AM
  #66
silver-mod-o's Avatar
Hunt&Fisherator
Looking good,
You ever thought about doing adapter plates on the block with hoses to a remote mount water pump? Makes packaging much easier and opens up a lot of options. Just a thought.
Old May 22, 2013 | 05:15 PM
  #67
sprayed99's Avatar
Originally Posted by silver-mod-o
Looking good,
I don't think it would make packing easier or really open any options.
I have to run 2 lines for A/C, 2 lines for Heater, 1 7/8th header tubes, wiring, PCM mount, and trans cooler/lines on the passenger side
Driver side will have the same header tubes, steering linkage, unisteer cross steer mount, under floor master for brakes, and fuel lines.
So needless to say running 2 lines for a remote waterpump is out of the question or at least I'm choosing not to even think about it LOL, but thanks for the suggestion.
Old May 23, 2013 | 09:26 AM
  #68
Hunt&Fisherator
Considered relocating the coils under the body while you've got the wiring apart? It would clean up the top of the engine a bit.
Old May 23, 2013 | 10:03 AM
  #69
TXsilverado's Avatar
consider selling it to me. awesome truck!
Old May 23, 2013 | 11:26 AM
  #70
idahoblkss's Avatar
look at post 61 second picture down .... newb ! lol
where are the turbos danny ?
