05 RCBS 4.8 5Spd Turbo
Old Oct 20, 2018 | 11:26 PM
treylittlefield's Avatar
anxious to see how you like the 78/75 on a 4.8. Is it the billet wheel?
Old Oct 21, 2018 | 02:09 PM
Teeny05's Avatar
Yea me too, I think it will be great. Non-billet.
Old Oct 26, 2018 | 10:30 PM
Teeny05's Avatar
[img][/img]
Crossover mock up, 2" or so clearance between pipe and trans
1"~clearance to floor, plenty of room for downpipe
Stuck with the original drivers side flange to manifold
All welded together besides the Vband which connects passenger side to huron manifold. Got that done and it bolts up great.
Old Nov 6, 2018 | 09:13 PM
Teeny05's Avatar
Turbo Smart BOV flange welded on by a friend. 5 Wire MAF converted to IAT and Flex Fuel Sensor pigtails. ZR1 MAP installed.
Snakeeater Performance 1500s
Flex Sensor, injectors with adapters, rail spacer kit, map sensor with wiring adapter.
turbo feed plate and 5 wire maf harness pulled free. Dont buy IAT/Flex fuel extension harness, plenty of wire already available.
Old Nov 7, 2018 | 10:19 PM
Teeny05's Avatar
Return rail with SEP 1500s, new regulator.
Rail installed. Needed a 3/4" spacer instead of 1/2"...maybe cause its an 00 rail on an 05 intake??? No idea. But should get the job done.
Flex sensor installed. Not the nicest thing but should work for now.
Move Yellow wire from Green 32 to Blue 56 and Tadah! You got flex!
Old Nov 8, 2018 | 01:45 PM
chevykev's Avatar
Looks sweet man. Keep up the good work. I’m doing a 5.3 build but my truck is nnbs and has stock flex. Hoping for 550 wheel but we’ll see. Just curious why go flex fuel? Couldn’t you have installed a walboro or something to support more hp?
Old Nov 8, 2018 | 04:24 PM
Teeny05's Avatar
Going E85 for higher octane and cooler charge temps so I can raise the boost without using Meth. Its cheaper than race gas. Im putting a Walbro 450 in, should get me to my power goals for now. Thanks man.
Old Nov 9, 2018 | 12:45 PM
chevykev's Avatar
Yea e85 is about 10 miles away from me idk if that’s worth the travel for me or not for a daily driver
surffly
Nov 29, 2018 01:31 PM
Slo4.8
Aug 10, 2018 11:10 AM
2000silvrx81
Mar 3, 2012 10:37 PM
jkwalkercchs
Mar 8, 2009 07:02 PM
1slow60
Nov 26, 2003 08:52 PM
