03 SS awd turbo street build
Old Feb 13, 2017 | 12:56 PM
  #41
SDjeff619's Avatar
Originally Posted by 001HD
that pipe fits really well through there man looks good
Thank you....
Kind of in a bind and don't have time to order a LS Valley cover lift plate, anyone think this universal one will hold with only 4 Valley cover bolts? It's just the short block, thanks in advance
Old Feb 13, 2017 | 01:09 PM
  #42
wretched73's Avatar
You'll be fine
Old Feb 15, 2017 | 09:20 AM
  #43
SDjeff619's Avatar
Picked up the Thompson 370 and cnc 799's
Old Feb 18, 2017 | 11:11 AM
  #44
SDjeff619's Avatar
Any opinions on what rockers, lifters and pushrods to use on the daily driven 800hp build?
I know now the majority runs LS7 lifters but there is another reliable more quiet option out there? Seems like most aftermarket ones I read about are short lived with failures.
As for rockers, initially I was going with oem rockers and the Straub or Smith Bros trunion. Any expierence with aftermarket roller rockers, even maybe Summit brand?
And then pushrods, there seems to be a ton of options out there.
Heads are 799 cnc, stock sized valve with 660 springs . I don't have the cam specs on me as of now.
Old Mar 8, 2017 | 08:26 PM
  #45
SDjeff619's Avatar
Anyone with a 4" downpipe? I'm building mine and holy **** there is no clearance between the firewall/frame/crossover piping. The only way I can see to gain any more clearance is to build a new crossover pipe. Trick turbo, any recommendations?
Old Mar 8, 2017 | 08:42 PM
  #46
GMCtrk's Avatar
They fit, but tight.
Check your motor mounts and the side to side alignment of the motor.
Also, I highly recommend solid motor mounts
Old Mar 8, 2017 | 08:53 PM
  #47
SDjeff619's Avatar
Solid mounts on a daily driver? How do they feel? I'm making everything up with the old block and old mounts. At the minimum I planned on buying new stock engine mounts.n I AM worried about the engine shifting and the downpipe sitting on the inner frame
Old Mar 8, 2017 | 08:55 PM
  #48
GMCtrk's Avatar
The solids aren't really noticeable at all, especially if you're already cammed.
I would consider solid motor mounts almost a must on a serious turbo build
Old Mar 8, 2017 | 09:48 PM
  #49
SDjeff619's Avatar
Thanks for the advice, I'll be looking some up. I really have no room for movement with this downpipe.
Old Apr 9, 2017 | 02:20 PM
  #50
SDjeff619's Avatar
Haven't updated here in a while but here's more pics. ​​​​​​​
My second version of the 5" intake
Second version of the 3" charge pipe with Tial 50mm and IAT bung.
Had some couplers made with my Purpose Built logo
I got way too excited about these stickers lol awesome quality.
