03 SS awd turbo street build
Old Feb 5, 2017 | 05:00 PM
  #31
SDjeff619's Avatar
AkSSS
Did you do the trans work yourself?
Old Feb 6, 2017 | 12:00 PM
  #32
AkSSS's Avatar
Originally Posted by SDjeff619
AkSSS
F*CK no. I am not that skilled. HAHAHA
I had a local guy put it together. I just took him the parts that I wanted in it.
Old Feb 8, 2017 | 03:12 AM
  #33
SDjeff619's Avatar
Here is the upper and lower intercooler brackets I made for the 31x12x4. The challenge was to get the IC as high as possible to fill the majority of the grill and pushed back to clear the factory grill mesh. I moved the hood latch back 5/8", the max I could do without modifying or relocating the hood hook bar itself. The back side of the IC is very close to the hood latch assy so I needed absolutely no movement of the IC while driving.
Old Feb 8, 2017 | 11:27 AM
  #34
thewrx's Avatar
Originally Posted by AkSSS
On the drivers side fuel rail, I had edelbrock rails with 1/2npt. Not sure if the holley has O-ring boss or Npt threads. I had to get 1 fitting that was a 1/2npt to a 90*#8. I tried a straight 1/2npt and then putting a 90* #8 fitting on it and it hit the alternator. So the fix is to keep it to one fitting that screws into the rail and makes your 90* also.
same problem on my tbss with holley, ill take a pic of mine.
Old Feb 8, 2017 | 12:24 PM
  #35
ILuvJDM's Avatar
Man that's awesome, glad to see you are getting it to work. I take it you have the smaller radiator and you're going to go between the headlights and radiator?
Old Feb 8, 2017 | 06:07 PM
  #36
SDjeff619's Avatar
Thanks, it's coming along little by little. And no, I have the big radiator, routing the piping between the head lights and around the core. It just takes a little tweaking of the a/c lines going to the condenser.
Old Feb 8, 2017 | 06:18 PM
  #37
Lil Red S10's Avatar
i'm in love with that brake setup... the turbo... hell the whole build.
Old Feb 12, 2017 | 03:05 PM
  #38
SDjeff619's Avatar
Got some progress on the project, manifold and s480 mounted for mock up. Fabbed up the 3" stainless charge pipe. I though clearance would be an issue but the only thing that needed to be trimmed was the plastic head light mount. I'll be making some bracing brackets for the head light mount since the lower section isn't secure due to the material i had to remove to fit the IC pipe.
Old Feb 13, 2017 | 10:43 AM
  #39
001HD's Avatar
that pipe fits really well through there man looks good
Old Feb 13, 2017 | 10:47 AM
  #40
Vortec350ss's Avatar
This thing should be a blast!
