03 Sierra Prostreet Paperweight
#24
Well, had the engine picked up and taken to Triple Edge Performance today. Going to have them look it over, install my Triple 12, studs, melling 10295, and all new gaskets. Then freight it to me with my 4L80e and Precision TC. Anything I am missing? Trunion setup?
For now I wait... And I am going to try a new crank sensor on the 4.8 to see if that helps. Time is hard to come by, so hoping to have that done by the weekend.
Also chasing some current draw from an unknown source. Radio fuse is already pulled, but I am going to hookup the DMM to the battery and start pulling fuses until I can find the source. Then I will try to rectify that issue as well. Seems like im always moving backwards, never in the right direction
DW also called me back today about my suspect DW350iL issue I had. They are going to warranty out the pump and send me a brand new one. Even though I already bought one local, I will either keep this for future use, or sell it for some other random parts.
Staying the course, wasting the money, enjoying the hate.
#25
Usually it's aftermarket Radio Equipment and aftermarket alarms/ remote starts that cause it.
Check anything aftermarket first.
#26
Yea, I wiped out the AM radio first, but that guess was wrong. Truck does have AM alarm and remote start, so I think your point in valid. Going to check it during the hunt. Hopefully make some progress.
#28
Still being a ghost whisperer tonight...
When I rev the engine to right around 2k, it then drops a cylinder... But if I rev it and hold at right around 3k, it stays solid. So it is breaking up much more right around 2k. You can hear/feel it literally drop a cylinder at that rpm. Also unplugged the MAF sensor and it ran basically identical as plugged in.
Obviously when it is just at idle and has the random missing, you can tell it isn't running 100%, but I think the 2k drop might be something to help diagnose?? Thoughts?
My new crank sensor and spark checker showed up tonight, will try to get them installed this weekend to see if anything changes. If no change, I might swap in my 60# Siemens to rule out injectors. Running out of things to try, but still have a minor hope to figure it out before the 5.3 arrives.
