**Three6GMC Official Build Thread**
Old Jan 15, 2017 | 03:32 PM
  #581
03sierraslt's Avatar
Damn nice numbers, and like others have said those dudes were stupid. Not strapped down near enough and horrible location to sit or stand.
Old Jan 15, 2017 | 03:43 PM
  #582
Three6GMC's Avatar
Originally Posted by GMCtrk
Those guys are silly sitting there during the dyno. Driveshaft comes out, they might end up missing bodyparts.
986 is pretty stout on only 11 lbs. Probably similar to what I was making at 22 psi. Should be wicked once you turn it up.
Totally agree... I told the people I was with there to stand way back because of this. The driveshaft is high speed balanced but I still don't trust them. Seen too many come out.
Old Jan 15, 2017 | 03:45 PM
  #583
TrickTurbo's Avatar
Truck Sponsor
Originally Posted by Three6GMC
I know had me a little worried, when I showed up and saw they didn't have front straps and little rear straps I knew it was going to be sketchy. In I believe the second video look at the tire... I think the truck moves forward so much it rubs the ramp and glazes the tire a little bit. They just opened up the shop and had barely installed the dyno the day before so I just wanted to show my support. I'm sure they will fix that here quick.
Yea always keep your truck safe. Falls to you. Cool supporting the shop, and bad *** numbers for sure.
Old Jan 15, 2017 | 03:48 PM
  #584
TrickTurbo's Avatar
Truck Sponsor
I've seen a driveshaft go flying bad mojo there.
How's the truck from a dig? With those turbos?
Old Jan 15, 2017 | 05:41 PM
  #585
Three6GMC's Avatar
My front shaft comes in Tuesday so I'll be doing some 4 hi launches here pretty soon. Reason why I haven't posted a lot of street running videos, truck is useless in 2wd.
Old Jan 16, 2017 | 07:08 AM
  #586
thewrx's Avatar
Originally Posted by Atomic
That thing is not strapped down near hard enough on the dyno!
thats because its a "dynamite!" Dyno
it dont need no stinkin strap ons
bad *** truck, not breakihg a sweat
Old Jan 17, 2017 | 06:34 AM
  #587
Dbyers2's Avatar
formery SilverSleeper1500 (12-06-2011)
They are in mass production lol... They are brackets that are supposed to replace the metal coil mount bracket on Ls valve covers. They happen to fit perfectly down low by mounting them off the back bolt on the ac compressor and off the power steering support bolt on the side of the block. What I used for bolts were those stud type transmission bolts, the one that are a m10 1.50 on one side and like a m6 on the other. That let me replace the stock bolts on both sides of the block and add a stud to mount the coil bracket to. Hopefully that makes sense, if you need better pics I'll get them for you.
https://m.summitracing.com/parts/icb...fLTxoCzW_w_wcB
No way that's awesome thanks for the info! I'll look into this weekend I'll pm you if I need some more pics. Nice going on your last dyno day 1k+ crank hp all on your own 👏👏👏
Old Jan 18, 2017 | 01:27 PM
  #588
crashmymax's Avatar
Your truck is simply amazing! I don't know how you manage the time to make everything that clean. I used to be **** like that until the kids started coming. Now that I have 5 I don't even care when they eat in my truck anymore.
I really like how you deleted the coolant tank for more space. How has that worked out? Any issues? I might copy you on that one if you had no problems.
Great truck!
Old Jan 18, 2017 | 08:32 PM
  #589
Three6GMC's Avatar
Thanks lol, I just take my builds step by step. Plenty to improve on but I get it done piece by piece when I have the time.
I been running a deleted coolant tank for a few years now and I have yet to have any kind of issue. I live here in South Texas so 100+ degree weather is very common and never even got close to overheating even when racing. Saves a lot of space... I believe I posted what parts I used in one of the older posts would have to go back and check but very easy to do.
Old Jan 18, 2017 | 08:45 PM
  #590
Three6GMC's Avatar
Well any 2wd runs are out of the question... good thing is I can do a rolling brake boost fairly easy. Turbos light off pretty good.
https://youtu.be/DROcBR3CxTg
Not sure why its not displaying the you tube video like my other ones but link is there to click on
