HELP!-Problem with programmer
Old Jan 16, 2010 | 09:15 PM
5point3Z71's Avatar
Default HELP!-Problem with programmer
My friend has a 2006 F-350 with a 6.0 and when he installs his Edge Platinum Juice programmer it blows white smoke and gains no power at all. When the programmer is not in the vehicle the truck does not blow smoke and runs fine. Edge tested it and said the programmer is perfectly fine. He also used someone elses exact programmer and it did the same thing. So we can only assume the problem is in the truck. Any ideas? Or know of another site more aimed at Ford trucks?
Thanks in advance, Matt.
Old Jan 16, 2010 | 09:53 PM
viciousknid's Avatar
Where's the Beef?
Either the glow plugs aren't getting up to temp or he has a water leak. could be a head gasket that doesn't leak until he starts making more power? Make sure the coolant is full and also check the EGR cooler according to searches i've done.
Old Jan 17, 2010 | 08:48 AM
venomhp's Avatar
sometimes the EGR can leak, also FYI edge programmers suck. If you want a real tune get an SCT with a custom tune. My brothers truck is pretty badass with his tunes, but with an edge, they dont tune the transmission to go with the power, so you can run into problems in a hurry.
Old Jan 17, 2010 | 12:41 PM
5point3Z71's Avatar
Ok, Ill have him look into that. The first thing I thought when he said white smoke, was a head gasket.
Ill let him know.
Thanks guys. Any other info would be greatly appreciated.
Old Jan 17, 2010 | 11:59 PM
Where's the Beef?
if his collar is popped tell him to stop being gay and put it back down.
Jersey stereotyping.... sorry.
Old Jan 18, 2010 | 12:04 AM
SLOXCAB's Avatar
You forgot fist pumping
Old Jan 18, 2010 | 08:49 AM
5point3Z71's Avatar
The two dumbest replys I have ever had in a thread. If you know nothing, please keep the comments to yourself.
Old May 5, 2010 | 08:28 PM
snow white's Avatar
sounds more like an overfueling problem. i agree the edge programmers aren't the best choice as ford has stepped up their software encryption. i have heard from a few reputable tuners that with the new software update the 6.4s are un-tuneable. the pcm just locks up and has to be replaced
outlawz2004
Sep 19, 2015 08:12 PM
MikeD.
Sep 18, 2015 09:55 AM
OVOAustin
Sep 15, 2015 08:32 PM
Tx98Formula
Sep 10, 2015 01:03 AM
BIGD4504
Jul 28, 2015 11:46 AM
