Wet/dry
Old Aug 2, 2006 | 02:29 PM
graysilv's Avatar
Default Wet/dry
Which Nitrious Set Up (wet Or Dry) Do You All Recomend? Why?
Old Aug 2, 2006 | 02:40 PM
silver-mod-o's Avatar
Hunt&Fisherator
definitely a wet kit... much safer and easier to tune than a dry shot... you normally end up getting more tq out of a wet kit as well.
Old Aug 2, 2006 | 02:56 PM
goshawk23's Avatar
Truck addict
wet kit. i started with a wet kit so i'm partial. never used a dry so i can't speak bad of it.
Old Aug 2, 2006 | 05:15 PM
An11secRanger's Avatar
I wouldn't say either one is "safer". They're both completely safe with proper installation and tuning.
I recommend the wet kit because the dry kits are (hp) limited by the fuel injectors.
Of course, you may need a bigger fuel pump with either system. But, with a wet kit, you won't have to use bigger injectors. That, to me, is a plus.
Old Aug 2, 2006 | 06:09 PM
goshawk23's Avatar
Truck addict
you will more likely need a fuel pump before bigger injectors but i say keep it safe and do both. but tune for injectors......
Old Aug 2, 2006 | 06:22 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
there are TONS of threads on this search this forum
Old Aug 17, 2006 | 10:33 PM
Robert56's Avatar
Dry is safer by a matter of fact and proven track record when comparing to wet hits. Can you say swelling fuel noid plunger, or intake and hood removal, now these do not happen on a dry hit, period, so is wet safer, no way. Now wet dose have it's place, don't get me wrong, just stating the facts.
Robert
Old Aug 18, 2006 | 12:15 AM
goshawk23's Avatar
Truck addict
Robert
never had that stuff happen to me.
Old Aug 18, 2006 | 11:05 AM
"swelling fuel noid plunger" is possible so, in that regard, you win.
However, it's not the most prominent problem in the world. And it's really not a problem with properly maintained kits. My small kit (Compucar) is over ten years old and this has no been a problem. My big kit (NOS) is eight years old and this hasn't been a problem. My brother's kit (NOS) is six years old and, again, this is not a problem. Remember ,the two bigger kits are NOS kits, which, IMHO, isn't the best brand out there.
But, like I said, you're right. And you provided some insight. I just don't think it's worth all the extra expense for most people who want a bigger hit than the dry kit will afford them with stock injectors.
On the other hand, there are some intake designs that require the use of a dry kit without major extra expense. So, there is a place for both, wet and dry, designs.
Old Aug 18, 2006 | 11:46 AM
slowprocess's Avatar
Robert
Are you guys seeing more of this lately? I've noticed a few threads around the net about this. I've heard a few people say it was because of the additives in the fuel. Is this correct? Thanks
