Wet/dry
#25
Ok guys here is a great example. My nitrous noid was acting up and spraying, not spraying then froze up today at the track. Well, I am happy to report that no issues arose except the pride issue causing me not to be able to back up my smack. Now if this was a continuse issue with a wet hit before diagnosing problem, possibely this would have happened;
, slight chance yes, but still a chance.
Robert
, slight chance yes, but still a chance.Robert
#26
I have been spraying mine with a 175 dry shot no problems i have it tuned to run fatter on the spray, but i do have bigger injectors and hptuner so i can test and tune, but this weekend i will be 2 staging it first stage dry then 2nd stage wet think im gonna go 100 then come in with a 150 wet and i will be putting in a bigger pump
#28
OK, time for the totally ignorant outside observer to chime in.
Robert, I think you hit the nail on the head on the dry/wet controversy. GM trucks have a MAF, so a properly placed N2O nozzle can use the MAF to its advantage to provide a tunable, safe system. Many other vehicles (e.g. Dodge hemi, Honda) use a speed/density system with no MAF, and so this technique cannot be used. For them a dry shot is probably a lot trickier to do, and a wet might be safer. Same goes with the old-fashioned carburetor.
#29
Originally Posted by GenofiveO
Parish has hit his with a huge dry shot! But he does have a megasquirt to control all the fuel.
I did a home built dry shot (easy as crap) on mine and it knocked a solid 1.2 seconds of my E.T. on what was supposed to be a 100 shot, according to those in the know. I wasn't logging at the time, so I'm not sure exactly how "safe" it was, but I did run SEVERAL bottles through it with that "tune up". Just be careful on where you place the nozzle in accordance with the MAF, as I froze mine up being too close. If I was to do it all over, I would prob. relocate the MAF further up the intake tract and stick with the DRY shot. On a stock motor, I wouldn't want to go too big anyway, and feel confident that the stock injectors and MAF can handle the baby shots that I use. SPEEDY02, have you hooked the kit up yet or what??
Couldn't find the original post, but check out post #8 in this thread:
https://www.performancetrucks.net/fo...uel+noid+stuck
usabodyguard
Oct 18, 2009 08:44 PM
BlackSilverado
Dec 13, 2008 07:59 AM
sgchap3
Aug 15, 2008 12:16 PM
DamnYankee
Jun 29, 2008 04:24 PM
