switch panel
Old Dec 10, 2009 | 05:49 AM
454navyss's Avatar
Default switch panel
i have seen a nitrous switch panel on a truck that went in the opening to the left of the steering wheel (where the 4wd button goes) i though it was a nitro dave's panel but the only one i see on their website is the one that goes where my airbag on/off switch is below the heater/ac controls. can anybody lead me in the right direction to find the panel im talking about? thanks
Old Dec 10, 2009 | 08:45 AM
slowprocess's Avatar
http://www.nitrousoutlet.com/catalog...7&product=2182
Old Dec 10, 2009 | 09:36 AM
454navyss's Avatar
thank you. i guess i should have checked out each part number instead of just scrolling through
Old Dec 10, 2009 | 09:58 AM
thank you.
Old Dec 11, 2009 | 01:51 AM
TxStVanWilder's Avatar
thats the switch panel i have carey.... if the truck is put together on sunday ill show it to you
Old Dec 11, 2009 | 02:54 AM
454navyss's Avatar
sounds good alan, if i get that panel i will have to find somewhere else to mount my fan switches......
Old Dec 11, 2009 | 11:46 PM
fastrt's Avatar
11 Second Truck Club
I got the same one. it is a little weird as far as mounting it to the inner dash bezel goes. I used machine screws to bolt it to the inner framing where the cubby hole/4wd buttons went. how did you guys fasten yalls? I got no instructions with mine to show you how to mount it either.
Old Dec 11, 2009 | 11:48 PM
Mangled03gmc's Avatar
Baltimore Whore
Old Dec 11, 2009 | 11:49 PM
00ChevyScott's Avatar
Wearin' da big hat
It says 99-02, so maybe there are screw holes on ours and not on the 03+ dashes?
Old Dec 12, 2009 | 12:00 AM
fastrt's Avatar
thats how I had my cutout. I should have put some more thought into it when I cut the hole for the cutout, cause I put it in the middle. didnt make room for future plans.
I guess I need to call and ask how they made it to work. it looks ok, just need flush screws to mount it. the screw heads are pushing the cluster bezel out a bit.
