Spraying while saving trans
Old Oct 21, 2011 | 11:53 AM
  #21
SRTKLLR's Avatar
When I first started spraying I had the window switch set to turn off the nitrous right before the shift then activate again after the shift. I did not like how the truck would nose over and it almost seemed like it was searching for the gear since the tq changed dramatically. I switched it to spray through the shift and it felt 200% better and gained a little ET to boot.
Old Oct 21, 2011 | 01:22 PM
  #22
05GMC4.8's Avatar
How long did or has it lasted doing this?
Old Oct 21, 2011 | 05:57 PM
  #23
Beatdown Z's Avatar
Laid Back
Just run more torque management, imo.
Old Oct 21, 2011 | 10:21 PM
  #24
SRTKLLR's Avatar
I just recently started spraying plus I have a built 4L60.
Old Oct 22, 2011 | 06:46 AM
  #25
LS1TRUCKGUY's Avatar
IMO, its harder on the drivetrain unloading and loading it like that... I spray through the shifts with some tm left in the tune. My bone stock 145k mile lasted about 10k miles on nitrous and my current trans with a shift kit, servos, trans cooler, and a wide 2-4 band hasn't missed a beat in the 5k miles
Old Oct 22, 2011 | 08:27 AM
  #26
JoeGibbSilverado's Avatar
Originally Posted by chevrolet all the way
dude, trying to keep a stock 60e together on spray is like saying im not pulling out but you better not get pregnant!
If you build the 60 it could be just fine as i sprayed through shifts and out of the hole on mine. A stock one is not going to hold up though. Not even without spraying through shifts. Im not saying i wouldnt try it, just be ready lol
:d lmao
Old Oct 26, 2011 | 02:18 PM
  #27
Team Paulie's Avatar
Registered User
150 shot and it has been holding so far,outta the hole all the way up.
Old Oct 29, 2011 | 06:59 AM
  #28
TheRepairMan's Avatar
Banned
i got about 20 bottles through a stock 4l60e trans on a 175 shot from the hole. no problems
Old Oct 29, 2011 | 09:34 PM
  #29
cheyenne_87's Avatar
will it still hold if its cammed and with a 3200 stall?
Go5.3tt06
Sep 12, 2015 09:29 AM
Jake99
Aug 8, 2015 07:56 AM
sprayed99
Aug 4, 2015 09:09 PM
dantheman1540
Jul 29, 2015 04:45 PM
vmaxpro
Jul 27, 2015 10:45 PM
