Spraying while saving trans
Old Oct 12, 2011 | 06:14 PM
Steve-O-08's Avatar
Nitrous Outlet and Harris Speed Works both have wide open throttle/window switches. Not spraying out of the hole and using the controller to shut the nitrous off 2-300 RPM before the shift and a progressive controller will help as well. A built transmission would be the best way keep it together.
Old Oct 13, 2011 | 09:19 AM
Nitrous Express's Avatar
Former Vendor
if you are trying to be nice to the trans i would definitely run a window switch
we have them as well as anything else you might need with your build
any questions feel free to call me and i will do my best to help ya out!
Old Oct 13, 2011 | 10:13 AM
livefast1's Avatar
Thanx I appreciate it. I ran one of your kits years ago on my stock mustang and shaved a second and a half off on street tires, was very happy with the kit.
Old Oct 13, 2011 | 10:39 AM
BlackGMC's Avatar
Resident Retard
lol... my performabuilt LV2 lasted 4.25 passes NA (broke on the 5th pass shifting in 2nd)... I have zero faith in the 4L60e...
Old Oct 13, 2011 | 11:18 AM
livefast1's Avatar
Yea it would be nice if i had a 4l80 core roll through the shop but i won't hold my breath. Think i replaced one in 7 years but i guess that says alot about the unit as well.
Old Oct 13, 2011 | 12:23 PM
TXsilverado's Avatar
sucky luck. i feel for ya man and you know ive been there with expensive parts with as many engines as i've been through lately
Old Oct 13, 2011 | 12:26 PM
chevrolet all the way's Avatar
dude, trying to keep a stock 60e together on spray is like saying im not pulling out but you better not get pregnant!
if you build the 60 it could be just fine as i sprayed through shifts and out of the hole on mine. a stock one is NOT going to hold up though. not even without spraying through shifts. im not saying i wouldnt try it, just be ready lol
Old Oct 13, 2011 | 01:18 PM
pl4yboy's Avatar
Banned
Originally Posted by lamborado
Oh ok, idk i wouldnt think it would last long at all, but a progressive will prolly be your best bet.
I'm all about ditching the stock 60e.... but I sprayed through the shifts on mine for 30k miles. Probably 10 bottles.
Old Oct 13, 2011 | 03:24 PM
08sierra5.3's Avatar
ya it wont last long i spray a 150 through shift and out of the hole on a stock trans with about 10 bottles worth and its on its last leg
Old Oct 21, 2011 | 06:32 AM
slowec's Avatar
Run the wot swith through a momentary switch you hold in you hand. That way if you lift off the throttle or let go of the button, it stops spraying. Practice with a small shot. Launch, roll 10 to 15 feet, spray, never lift, let off the button right before the shift, get back on the button after the shift. It also gives you the option to control spinning with the button instead of lifting off throttle. Cheap, fun, and fairly safe :-)
With a knock off vette servo costing 15 bucks, NOBODY should run a stock 60E !
