Spray plus boost
Old Jun 28, 2012 | 05:50 PM
  #31
1FastBrick's Avatar
Custm2500's Rude Friend
We have E85 it's just not as common E85 California
Old Jun 29, 2012 | 02:13 AM
  #32
blwn4.8's Avatar
i knownthere is e85 here but my point us that its atleast a 45 min drive from my house so too much of a hassle for me
Old Jul 2, 2012 | 05:12 PM
  #33
Neal@NitrousOutlet's Avatar
FormerVendor
You might start out with a 50 shot. Most likely a 50 shot is going to add 100 HP to the wheels because of the cooling of the air. Then you could work on going up from there.
Old Jul 2, 2012 | 08:34 PM
  #34
blwn4.8's Avatar
do you think it will be ok to run the current tune with a dry 50 shot or should i tune it fot it?
Old Jul 3, 2012 | 10:27 AM
  #35
FormerVendor
I would still look at getting tuned for it. You are still most likely have to pull some timing with the 50 shot.
Old Jul 3, 2012 | 10:32 AM
  #36
nonnieselman's Avatar
Whats your Injector Duty cycle right now?
You should have enough for a 50 shot dry.. but better double check.
and keep an eye on the AFR.
Old Jul 3, 2012 | 11:08 AM
  #37
FormerVendor
If your duty cycle is high you might look at doing a wet system if you have enough fuel pump in the car.
Old Jul 3, 2012 | 08:35 PM
  #38
blwn4.8's Avatar
will the wet shot bring temps down as much as the dry shot tho?
Old Jul 3, 2012 | 10:19 PM
  #39
lglowe's Avatar
Still gotta watch injector duty cycle with a wet shot too. A baby 30 wet plate shot on top of 9-10 psi added another 2-3 psi on my turbo setup.
Old Jul 6, 2012 | 12:18 PM
  #40
yea it will bring the temps down if your spraying before the IAT.
Texas5.3_1251
Mar 5, 2016 08:10 PM
2500ZL1
Sep 12, 2015 03:50 PM
sTNT971
Sep 11, 2015 02:38 AM
the owl
Sep 4, 2015 04:09 PM
06murder
Sep 4, 2015 03:54 PM
