Spray plus boost
Old May 21, 2012 | 11:20 AM
$ierraLY5's Avatar
Default Spray plus boost
Anybody spraying on a supercharged 5.3 with stock bottom end? I'm toying with the idea of a 100 shot in front of a twin screw pumping 8 psi on a NNBS 5.3 iron block. Any horror stories, tips, etc....
I know most guys don't like to divulge info on their N2O set-ups but you can chime in on "past" experiences or "buddies" set-ups.
Old May 21, 2012 | 11:23 AM
Mangled03gmc's Avatar
Baltimore Whore
I think 100 shot and 8psi will go :boom:
Old May 21, 2012 | 11:25 AM
smokeshow's Avatar
Mod with training wheels
On a newer engine, I wouldn't be so sure.. I have run 18psi with a 50 shot on my truck and no complaints.
Old May 21, 2012 | 11:26 AM
$ierraLY5's Avatar
You think, or you know? LOL, I "think" so too but others think not, there are loads of supercharged mustangs spraying more than that on stock Ford blocks. I want to believe a properly tuned LSX motor can take more abuse than a Ford engine.
Old May 21, 2012 | 11:38 AM
Baltimore Whore
Only 1 way to find out. Make sure the TUNE is SPOT on. I would turn the boost up, run a smaller shot. Oh yah have spare trans.
Old May 21, 2012 | 11:42 AM
$ierraLY5's Avatar
Oh yeah, one more valuable point, my DA in Colorado is usually 7000 feet, so my 8 psi of boost is more like 5 psi at sealevel.
Old May 21, 2012 | 01:55 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
I would turn the boost down, and run a larger shot.
Boost = higher IAT's, so if you have both, I'd run less boost and more nitrous.
Old May 21, 2012 | 02:11 PM
Baltimore Whore
Just need to have a good IC. I know it is hard for you maggie guys to grasp with your big ole heat pumps
Old May 21, 2012 | 02:22 PM
Ain't that the truth.
Old May 21, 2012 | 03:43 PM
nonnieselman's Avatar
Ive run 6psi with a 50 shot, and also run 9psi with the 50 shot..
100 shot is a big step.
Id start out at 50 and work it up slow and see what happens.. Pulling timing each step to make sure.
