some quick but important questions about n2o
Old Aug 10, 2009 | 11:45 PM
LA DP6.0's Avatar
Default some quick but important questions about n2o
i have a TNT kit... i want to install it but... im thinking about the effects...
what does it do to the motor? does it ware it down or what? i want to do a 100 shot... about how much will it lower my times
Old Aug 10, 2009 | 11:47 PM
A Low Dime's Avatar
13 Second Truck Club
It will probably blow within a few runs since your running a 4.10s and 6.0
Old Aug 10, 2009 | 11:48 PM
LA DP6.0's Avatar
d@mn are you serious bro?
Old Aug 10, 2009 | 11:50 PM
A Low Dime's Avatar
If you installed the kit as your truck sits now, it will probably run 13.5 @ 105.
Old Aug 10, 2009 | 11:53 PM
LA DP6.0's Avatar
damn to blow just for a 13.5 no way jaja
but why do you say that it will blow cuz of the 6.0 and 410s? curious
Old Aug 10, 2009 | 11:57 PM
A Low Dime's Avatar
With those tires, you would only run mid 13's.
I say that because if you look though the nitrous section, there are TONS of threads asking this question.
Old Aug 11, 2009 | 12:00 AM
SincalT/A's Avatar
Screw the 100 shot run a 125 from what I read there is a BIG difference.
LA DP6.0's Avatar
ohh srry jaja... naw but i wont run n2o with 20s... i will but some lighter tires and slick in the back... so what would you expect bro
Old Aug 11, 2009 | 12:02 AM
LA DP6.0's Avatar
i only have 100 and 150 shots.. but i dont feel like tuning for the 150 rather just have a regular tune and keep the 100 shot...
cuz its my daily driver
Old Aug 11, 2009 | 12:29 AM
SincalT/A's Avatar
If you do go with the 100 shot I would expect mid 12's if you hooked.Although I see one of the guys you are probably fimilar with posted running bottom 12's w/ a cammed 4.8 and a 125 which is why I recommended the 125.I think he posts on the site you came from rgvtruckperformance I think is what its called.
I don't see a problem with reliability on that small of a shot.Will it shorten the life of the motor simple answer is yes in due time.The way I look at it is you probably move on to a different setup before you actually damage the motor on 100 shot.
