some quick but important questions about n2o
i have a TNT kit... i want to install it but... im thinking about the effects...
what does it do to the motor? does it ware it down or what? i want to do a 100 shot... about how much will it lower my times
If you do go with the 100 shot I would expect mid 12's if you hooked.Although I see one of the guys you are probably fimilar with posted running bottom 12's w/ a cammed 4.8 and a 125 which is why I recommended the 125.I think he posts on the site you came from rgvtruckperformance I think is what its called.
I don't see a problem with reliability on that small of a shot.Will it shorten the life of the motor simple answer is yes in due time.The way I look at it is you probably move on to a different setup before you actually damage the motor on 100 shot.
