questions timing and fuel
Old Oct 8, 2013 | 01:13 PM
tim wellington's Avatar
Default questions timing and fuel
i have turbo truck.working 2nd project .i am very good on nos old school foggers and carbs .? how is u nos guys control timing when using nos through ecm or outside units like msd.thanks to anyone who want to share thoughts
Old Oct 8, 2013 | 01:50 PM
NitrousExpress's Avatar
Former Vendor
There are a couple of ways that it is commonly done.
1st being just pulling the timing out using a tuning program like HP tuners or EFI live. Down side to this is either you have to drive eh truck with the extra timing pulled which you may loose some horsepower, or you have to change the tine back and forth from when you are running nitrous and when you are not.
2nd is doing a controller such as the MSD timing twister or the Lingenfelter LNC2000. Both of these units hook up in line of your coil pack harnesses and delay timing whenever the nitrous is armed. Then when you kill the power to nitrous system it goes back to normal timing.
3rd is to trick the IAT sensor in to thinking the temperature is a lot hotter/colder than it actually is only when the nitrous is armed, and then going into a tuning program and using those cells to pull the correct amount of timing. There is a tone of info on here and LS1 Tech about how to do this.
Trey
Old Oct 8, 2013 | 02:02 PM
Default timing
thks i thing i am going option number 2 that more what i am use to.
Old Oct 9, 2013 | 04:09 PM
Former Vendor
That is defiantly the most popular way to do it.
Trey
Old Oct 10, 2013 | 10:54 PM
Driver311's Avatar
Trey
Trey do you think my lq9 would be ok on my 91 octane tune if I ran a 100shot and for safety ran some Sunoco 110 at the track? I only plan on using the nitrous at the track and I can throw the race gas in there for the time being until I get a better solution?
Old Oct 11, 2013 | 08:56 AM
Nitrous Express's Avatar
Former Vendor
yes, you should be fine on race fuel
Old Oct 11, 2013 | 06:48 PM
Driver311's Avatar
YOu think thats as far as I should push it? I mean Im not afraid to throw the 125 or even 150 jets in there if i get close to 11.9 LOL On race fuel It should keep knock to a minimum i would think and its been really cool out (40-60)degrees
Thanks for your time NX
Old Nov 15, 2013 | 02:17 AM
PonyJender's Avatar
Banned
Down side to this is either you have to drive eh truck with the extra timing pulled.
Old Nov 21, 2013 | 10:55 AM
Former Vendor
The higher the octane the more you can spray without pulling timing. If you are going to run 110 then that will be plenty of cushion to run 150hp. You may even be able to cut it a little with 91 octane to reduce fuel cost.
Trey
5.3lSilverado
25
Aug 29, 2016 12:48 AM
GMCtrk
Jul 17, 2015 06:39 PM
76k10chase
Jul 17, 2015 01:48 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
jrplz
Jul 9, 2015 12:07 AM
