nitrous timing on 5.3
Old May 24, 2011 | 09:00 PM
boostedrides's Avatar
Default nitrous timing on 5.3
How are you all going about pulling timing out when spraying?
What are you using?
Old May 24, 2011 | 09:13 PM
brandon6.0's Avatar
HSW nitrous interface is what i used. Worked great for me. Check it out on there website. I also, got it up for sale. If interested PM me.
Old May 24, 2011 | 10:12 PM
Steve-O-08's Avatar
Using the HSW Interface here, works great.
Old May 25, 2011 | 12:53 AM
LS1TRUCKGUY's Avatar
My timing is pulled via my tune. Im always on a n2o tune.
Old May 25, 2011 | 01:45 AM
Steve-O-08's Avatar
The IAT sensor resistor trick is another way to pull timing.
Old May 25, 2011 | 08:06 AM
2007chevy5.3l's Avatar
EFILIVE for me. Got the AFR dialed in and timing set as high as i could go with no KR. Hits hard.
Old May 30, 2011 | 05:53 PM
badass05chevy's Avatar
Banned
interface FTW
Old Jun 9, 2011 | 11:25 PM
bmd_CL's Avatar
what is the iat sensor resistor trick?
Old Jun 10, 2011 | 08:16 AM
JoeyGC5's Avatar
Changing the Inlet Air Temp sensor value to fool the computer and make the pcm remove the timing.
I use EFILIVE COS5 on my Vette for nitrous. The new shortbed im building will be a simular setup for the 50hp dry shot.
Choda
Jan 22, 2026 02:03 PM
Greatdivider
Sep 9, 2015 09:52 AM
kr1s
Aug 24, 2015 05:34 PM
walledition
Jul 29, 2015 08:54 PM
vmaxpro
Jul 27, 2015 10:45 PM
