Nitrous newb here needs help!
What's up guys? I need your help.
I have a 2007 Chevy Silverado NNBS that currently has an NX Spray bar system.
It only has a 5 lb bottle mounted underneath the passenger side rear seat. (crew cab) Which is fine because I only plan to run around a 25 shot. The reason for this is more the cooling effects to prevent rotor expansion in the supercharger instead under sustained periods of WOT. Additional horsepower really isn't necessary.
It currently runs at 21 pounds of boost and will see up to 24 in Houston at TX2K13, and it's doing that along with a Snow Stage III, twin 625mL Meth Injection system. Meth helped a ton but this will be even better, as the spray bar isn't doing as much as I had hoped.
With all that BS aside, I really just need to know what I should purchase to make this happen. And also I need input on button locations and what I should use to make the system spray only after 4,000rpm.
The truck is equipped with a transbrake and 2-step, and it leaves the line in four wheel drive, WOT, at 3,000RPM, and around 17 pounds of boost. Full boost comes in right as soon as you let go of the transbrake button and converter flashes to about 4,700. The problem is, alot of space around the drivers console is used up due to arming switch(s), transbrake button, meth controller, etc. Also, the little cubby in the 2WD versions is out because the **** is there for the transfer case.
Pics would be great of ideas.
Let me know what else I need to post up to make this easier to make work.
Thank you.
Pics would be great of ideas. Let me know what else I need to post up to make this easier to make work.
Thank you.
not a readily available one {gto, fbody style}
that whole center section pops out, you could build one to fill that, and possibly move the cup holders to the passenger side of the console. or build something that would fit in the giant armrest/console itself. or take that little coin holder thing by the hvac and turn it into a switch panel with some low profile switches.
The rest will be handled electronically with some sort of nitrous window over WOT switch. Since I tune it real rich on the boost, around 10.8 AFR with meth I expect low 11's on the nitrous without the need to pull timing. So that means it'll still run fine without changing the tune.
If not, I'm going to do like you said and make a small switch bracket by the HVAC controls.
Thank you.
Thank you.
NX makes a custom switch panel for the new trucks
CUSTOM SWITCH PANEL, GM TRUCK 2008-CURRENT
gavin2005
Sep 13, 2015 09:04 PM
06murder
Sep 4, 2015 03:54 PM
