nitrous bottle heaters ?
ok so i need to get a bottle heater .but i cant decide witch to get ? i seen one from zex that plugs in the cig lighter its thermo controled. then the nx one is very low wattage, compared to the brand x, and harris 300watt heater . or is the pressure controled better? the prices are all over the place . nx being most $$ and less watts and the others more resonable price and more watts so it should heat faster?
There are differences in heaters. From the sounds of it you are looking for a wrap around silicon style heater.
If that is what you are looking for there are a few options.
Heater element with a relay that you turn off and on, Temp controlled, and pressure controlled.
A heater element with relay will be your cheapest route. You will have to watch the bottle pressure and turn in off when the bottle gets up to pressure.
I dont care for the temp controlled heaters. The thermostats are bad about burning out.
The pressure controlled is my favorite. They use a pressure switch that mounts at the bottle. Once the bottle pressure reaches the set pressure it will turn its self off and back on.
We offer our Brand X style wrap around heaters in element only andf pressure controlled.
But if you want something with alittle more style check out the Nitrous Outelte heater where the bottle bracket and heater are all made in one.
Dave
Dave
Can't go wrong with nitrous outlet stuff for sure. I have their brand x wrap around heater and a pressure switch that I pieced together. Great company with even better customer service
gavin2005
Sep 13, 2015 09:04 PM
06murder
Sep 4, 2015 03:54 PM
