nitrous bottle heaters ?
Old Dec 19, 2011 | 07:55 PM
6789olds's Avatar
Default nitrous bottle heaters ?
ok so i need to get a bottle heater .but i cant decide witch to get ? i seen one from zex that plugs in the cig lighter its thermo controled. then the nx one is very low wattage, compared to the brand x, and harris 300watt heater . or is the pressure controled better? the prices are all over the place . nx being most $$ and less watts and the others more resonable price and more watts so it should heat faster?
Old Dec 19, 2011 | 08:04 PM
Phantom's Avatar
11 Second Club
whatever is cheapest...
Old Dec 19, 2011 | 08:34 PM
6789olds's Avatar
ok cool
Old Dec 19, 2011 | 09:22 PM
Nitro Dave's Nitrous Outlet's Avatar
LS1TECH & TRUCK Sponsor
There are differences in heaters. From the sounds of it you are looking for a wrap around silicon style heater.
If that is what you are looking for there are a few options.
Heater element with a relay that you turn off and on, Temp controlled, and pressure controlled.
A heater element with relay will be your cheapest route. You will have to watch the bottle pressure and turn in off when the bottle gets up to pressure.
I dont care for the temp controlled heaters. The thermostats are bad about burning out.
The pressure controlled is my favorite. They use a pressure switch that mounts at the bottle. Once the bottle pressure reaches the set pressure it will turn its self off and back on.
We offer our Brand X style wrap around heaters in element only andf pressure controlled.
But if you want something with alittle more style check out the Nitrous Outelte heater where the bottle bracket and heater are all made in one.
Dave
Old Dec 19, 2011 | 09:26 PM
Phantom's Avatar
11 Second Club
Can't go wrong with nitrous outlet stuff for sure. I have their brand x wrap around heater and a pressure switch that I pieced together. Great company with even better customer service
Old Dec 19, 2011 | 09:31 PM
6789olds's Avatar
that brand x i think is what i am looking for cause i already have a billiet mount . do u offer any discounts to pt.net members ?
Old Dec 20, 2011 | 05:33 PM
We have a 10 percent off sale going until december 2nd.
Old Jan 19, 2012 | 03:21 PM
Team Paulie's Avatar
Registered User
Bottle heater on a on/off switch is what I got,remote psi gauge would be sweeter.
Old Jan 19, 2012 | 08:45 PM
08sierra5.3's Avatar
Go with a nano setup. Well worth the money!
simman22
Jan 21, 2017 10:27 PM
1slwgto
Oct 1, 2015 01:51 PM
gavin2005
Sep 13, 2015 09:04 PM
BlackGMC
Sep 9, 2015 01:43 PM
06murder
Sep 4, 2015 03:54 PM
