Never used Nitrous and looking to get into it
A nitrous plate kit, window switch, fpss, TR6 plugs and tune adjustment will get you on your way to deep 11's with a low 12 NA time. If I could go back and do my kit over I would use the Nitrous outlet dual stage wet plate and split up the hit more. Your biggest problem once the kit is on will be traction.
I would say somewhere between 100 and 150 shot would really wake that truck up and put you deep in the 11's, tickling 10's......Also, are you running 26" or 28" slicks? I know some guys with Lightnings have gone to using the 30" slicks to get alittle taller sidewall and more bite off the line. Just a thought to help you hook. Also, since you're spinning off the line you'll want a window switch to keep the nitrous from hitting off the line. With an extra 100-150 you'd really be spinning out of the hole.
I have a brand new NX MAF kit with 10lb bottle, billet brackets, 50-150 nozzles, Purge kit, and brand new never been used.
Originally cost $1500 shipped...
Selling for $900 shipped.
hit me up -
hit me up -
Nitrous has a bad name because it's so cheap to get started with. You can buy a $300 kit and throw it on your truck and technically it would function fine. Now that's where you run into problems. People negate all the safety equipment and then as soon as a problem occurs they have a much bigger and more expensive problem. I have close to $800 into my nitrous system and I bought everything used. I have a list a mile long that most would say is overkill, but it never hurts to be too sure.
Check out the HSW MicroEdge. It has a window switch, lean shutoff, gear lockout, and a TPS (WOT) switch all in one for a crazy cheap price. The thing is crazy, and worth every penny. Give the guys a chance at your business. I know they will win you over.
