Never used Nitrous and looking to get into it
Old Aug 12, 2009 | 08:54 PM
Dbyers2's Avatar
formery SilverSleeper1500 (12-06-2011)
Haven't heard a whole bunch of good things about the ZEX solenoids or the Nitrous management unit I preferably like the NX solenoids wrapped in carbon fiber
Old Aug 12, 2009 | 10:20 PM
Dark Halo's Avatar
Originally Posted by tarinitup
A nitrous plate kit, window switch, fpss, TR6 plugs and tune adjustment will get you on your way to deep 11's with a low 12 NA time. If I could go back and do my kit over I would use the Nitrous outlet dual stage wet plate and split up the hit more. Your biggest problem once the kit is on will be traction.
will this be a piece together kit or can I buy this as a kit?
Old Aug 12, 2009 | 10:25 PM
Dark Halo's Avatar
Originally Posted by tommy1005
I would say somewhere between 100 and 150 shot would really wake that truck up and put you deep in the 11's, tickling 10's......Also, are you running 26" or 28" slicks? I know some guys with Lightnings have gone to using the 30" slicks to get alittle taller sidewall and more bite off the line. Just a thought to help you hook. Also, since you're spinning off the line you'll want a window switch to keep the nitrous from hitting off the line. With an extra 100-150 you'd really be spinning out of the hole.
I am using 28's but only 9" wide. I am going to a 10.5 so I will see how that works.
Old Aug 12, 2009 | 10:30 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Call the guys at Nitrous Outlet, they will fix you up with everything you will need for a safe kit. Dave and the guys are really helpful.
Old Aug 12, 2009 | 10:47 PM
Dark Halo's Avatar
I will, just wondering what the max shot the stock bottom end will take
Old Aug 12, 2009 | 10:54 PM
Black'Rado's Avatar
i think stock it can handle aprox 150-200 range
Old Aug 12, 2009 | 11:12 PM
i've been using a 175 shot on my nx kit nitro dave built me for 5 years and it hasn't hurt anything yet it's all in the tune though.
Old Aug 13, 2009 | 12:00 AM
usabodyguard's Avatar
Blown 427 LSX
I have a brand new NX MAF kit with 10lb bottle, billet brackets, 50-150 nozzles, Purge kit, and brand new never been used.
Originally cost $1500 shipped...
Selling for $900 shipped.
hit me up -
Old Aug 13, 2009 | 12:24 AM
RandomHero's Avatar
Nitrous has a bad name because it's so cheap to get started with. You can buy a $300 kit and throw it on your truck and technically it would function fine. Now that's where you run into problems. People negate all the safety equipment and then as soon as a problem occurs they have a much bigger and more expensive problem. I have close to $800 into my nitrous system and I bought everything used. I have a list a mile long that most would say is overkill, but it never hurts to be too sure.
Old Aug 13, 2009 | 02:58 AM
jmill96Z's Avatar
10 Second Club
Agreed. When money gets tight, first thing out the window is usually safety stuff. The newest trick is the lean shutoff setup. Basically you just set you rich and lean limits, and the controller will kill the setup if you exceed the defined limits.
Check out the HSW MicroEdge. It has a window switch, lean shutoff, gear lockout, and a TPS (WOT) switch all in one for a crazy cheap price. The thing is crazy, and worth every penny. Give the guys a chance at your business. I know they will win you over.
