N.O. 90mm wet plate to 2 stage converswion help
Could anyone point me in the right direction, I have a 90mm wet plate kit from Nitrous Outlet and just had a stroker build and want dual stage for it instead of wet plate. Its a ly6 stroker with l92 intake on a 08 ecsb
You can add two extra solenoids into the same plate. Using a y or t. I like the y better. Just spray the first set like 100 shot then shoot the second set at like 150. U can spray bigger if the plate will flow more. I've built tons of nos kit. Make sure to flow the system to make sure your fuel system will flow the bigger kit.
How much are you lookingh to spray? What does your stroker motor consist of build wise?
Another option would be to put a progressive controller on what you already have. Then you can up the shot and progressively bring it it. This method would be much cheaper.
I will be more than happy to guide you in the right direction.
Dave
I am looking at a 150 wet shot. The engine is a stroked ly6 block with 4340 pistons, forged crank and nitrate piston rings. The builder said its good up to a 200 shot but recomended 2 dual stage if I was going to go 150 or above. I owuld love a 200 for the track
Ofcourse swaping to our dual stage plate and adding another stage is an option as well.
Dave
wickedRCSB
Oct 10, 2015 09:29 PM
