HSW Problems
Old Dec 17, 2007 | 01:34 AM
jaegmc99's Avatar
Default HSW Problems
I'm going to email or call them tomorrow but heres the scoop.
+ After I got my nitrous installed we tested it and all the lights on my BMN window switch worked perfect. Next day, no lights. Window switch is broken. Never actually got to spray with it. Figured what the hell, I'll just run the by toggle till I send the window back.
+Big problem tonight. Went to open the bottle tonight and my bottle heater pressure switch busted a leak and sprayed nitrous all over the back of my cab carpet and all over the heater wiring.
Two broken parts on this kit. What the ****!!!! Anyone else have probs with their kit?
By the way. don't touch frozen nitrous, that sht burns!! couldn't feel my finger for 5mins
Old Dec 17, 2007 | 01:57 AM
2002C5COUPE's Avatar
Which window switch do you have? Did you double check your wiring to make sure nothing came loose?
How did the pressure switch start leaking? Did the nipple break? Did you use teflon paste on it?
Old Dec 17, 2007 | 02:05 AM
jaegmc99's Avatar
We gave window switch power and it gave us no lights.It worked one day and not the next. Nothing was changed in between. I wouldn't even give a power light. The pressure valve thing blew the nipple and adjustment screw some where in the truck. couldn't find it and didn't want to touch the parts after almost freezing my finger off.
BTW it's a BMN window switch
The switch leaked between the two electrical connections where the adjustment screw is at. I'll try to trouble shoot it tomorrow if I can find the stupid screw.
Old Dec 17, 2007 | 02:17 AM
wow that's crazy. i havent had any problems yet with mine.
i can't say anything about that window switch, never had any dealings with them.
Old Dec 17, 2007 | 07:25 PM
99Silverado5.3's Avatar
my pressure switch broke as well, I was tightening it because it and it broke off and nitrous everywhere.... couldn't see crap...closed bottle and I do not have a pressure switch anymore.
Old Dec 18, 2007 | 03:26 PM
jaegmc99's Avatar
I emailed both HSW and BMN. I will update when I get replies
Old Dec 18, 2007 | 06:52 PM
KySilverado's Avatar
Yeah I lost a pressure switch after maybe 2 weeks. Turned the bottle on and got a handfull of cold gas out the end of the switch. They replaced it after I packed up the defective one and sent it back.
Old Dec 18, 2007 | 07:05 PM
bluecajun5.3's Avatar
11 Second Truck Club
same thing happened to me.
Old Dec 28, 2007 | 02:16 PM
496chevy's Avatar
so it sounds like their pressure switches are not the best quality?? or just a bad batch?
clint
Old Dec 28, 2007 | 07:07 PM
jmill96Z's Avatar
10 Second Club
I've never had a problem with their stuff. Have you gone through and checked the ground on the window switch?
