HSW nitrous plate installed
Old Jan 19, 2008 | 12:45 PM
bluecajun5.3's Avatar
11 Second Truck Club
Default HSW nitrous plate installed
just thought i'd share some pics with yall...
Old Jan 19, 2008 | 01:35 PM
TX Tahoe Z71's Avatar
Sweet! Is that the LS1 plate or do they make a truck specific plate? Have fun with it
Old Jan 19, 2008 | 03:26 PM
ZR1 DREAMING's Avatar
So when do the 150 jets go in?
You can get them for the truck intake as well as the LS1/6 intakes like Lance has.
Old Jan 19, 2008 | 05:20 PM
2002C5COUPE's Avatar
They are the same kits. The only difference in the 78mm kits (GTO vs. F body) are the solenoid brackets. Trucks need the GTO kits because they have the universal mounts.
Bluecajun probably got the f body kit because he's running an LS6 intake.
Install looks good! Post up some track results ASAP!
Old Jan 19, 2008 | 06:26 PM
00Silv4.8's Avatar
dam, I cant wait for the bottle! good luck man
Old Jan 19, 2008 | 07:48 PM
thanks everyone for the comments!
jordan, as soon as i can get traction, i will spray the 150.
Old Jan 19, 2008 | 09:33 PM
Wheatley's Avatar
Truck Sponsor
Looks great Lance
Old Jan 20, 2008 | 01:59 PM
Holty's Avatar
Notorious BIG
nice clean install, i like it.
Old Jan 27, 2008 | 09:30 PM
85mudblazin's Avatar
What fittings did you use to connect from the stock hard lines to the AN line??
Old Feb 7, 2008 | 07:56 AM
thanks again everyone
i believe they were some AN compression fittings. (male)
