fueling help.... need your opinion
what are you guys running as far as stand alone fuel systems kits for your nitrous set ups. i was looking at the nitrous outlets kit but 750 sounds a lil steep for a 1 gallon tank, pump,reg. , and a couple fuel lines. any help is good help.
the nx setup for $400 has an internally regulated pump? i wonder what fuel pressure/jetting is needed? pros/cons of each? the one above it is the same thing, but with an adjustable regulator, so you are pretty much getting the same thing as a HSW or trick dedicated system
what about timing tuners ? is there a box or something out there that senses the n20 a kicks the timing down so when your not on the bottle you dont have to load a different tune ?
I have read about an iat tricker or something, from what i understand it makes the computer think you iat is hotter then it actually is, thus pulling timing. Tryin to dig up where i found that at, im pondering the same question you are. Found the thread i was lookin for hope this helps : https://ls1tech.com/forums/nitrous-o...tor-trick.html
