Finally going to install it
Old May 12, 2015 | 02:54 PM
dmelvin's Avatar
Default Finally going to install it
So, I bought a nitrous kit a couple of years ago for my truck, and I've never gotten around to actually installing it. I think that will be my weekend project.
I have a couple of questions though. Currently my tune is a 91 oct Blackbear data log tune, should I get a hold of them and have them dial back my timing a few degrees (going to be spraying dry 75Hp).
The other one is a dandy of a question.... nozzle placement.
I'm running a Volant CAI with the stock MAF. However, when I was younger and dumber, I installed a throttle body spacer.... That has me thinking that I could drill and tap that and have a makeshift plate system. The system has a shark nozzle, I believe.
Also, what is the going rate per lb to get filled for you guys?
Truck Info
2002 5.3L
216/220 .525/.532
3200 Circle D single disc converter
Performabuilt Level 2 transmission
3.73 gears
243 heads milled .030 with a .040 head gasket thickness
Old May 12, 2015 | 03:26 PM
Nitrous Express's Avatar
Former Vendor
Depending on how aggressive they have your timing you might need to back it down, but definitely give them a shout on that. If running a dry setup you will have to place the nozzle before the MAF so it can read the change and adjust appropriately. We sell nitrous here for $4.50lb.
-Chris
Old May 13, 2015 | 02:21 PM
dmelvin's Avatar
-Chris
I knew there was a reason why some people sprayed in front of the MAF, but I couldn't remember what it was. Well that makes that part easy.
So paying $6.50/lb isn't outrageous for being in the middle of BFE.
Corvette454l88
Sep 1, 2016 01:24 AM
thunder550
Oct 8, 2015 04:53 PM
mrhino
Aug 7, 2015 10:01 AM
zblee
Aug 3, 2015 03:45 AM
GMCtrk
Jul 17, 2015 06:39 PM
