6.0l vin trouble
Old Feb 25, 2016 | 12:00 AM
ROGERZ's Avatar
Registered User
Default 6.0l vin trouble
I've been searching for 3 days and can't find out what exactly 6.0l engine I have. Any help would be greatly appreciated! C31396066
Old Feb 25, 2016 | 07:59 PM
FFDP's Avatar
Look at the VIN on the dash, pretty sure that a 8th digit U is a LQ4 and N is a LQ9.
Old Feb 25, 2016 | 08:09 PM
ROGERZ's Avatar
Registered User
Can't, it's a 55 chevy truck, and the engine was built by a guy that passed away. It's a 6.0l of something, but the numbers are dot stamped and don't cross reference to anything I can find.
Old Feb 25, 2016 | 08:21 PM
FFDP's Avatar
Look at the pistons then. Dished pistons are LQ4 and flat top are LQ9 if I remember right.
And the heads too, the old ones come with 317's and I think the LQ9's have 243's, but maybe not all.
Old Feb 25, 2016 | 08:43 PM
George C....'s Avatar
Formerly ScreamingL
No lq9 didnt have 243s
Old Feb 25, 2016 | 10:59 PM
Wolftrk99's Avatar
Gen iv 6.0s will have iv 6.0 cast into the block, gen 3just has 6.0 cast intonit, gen 3 flat tops were typically lq9 dished were mostly lq4, have seen a few supposed lq9's, by vin and rpo that had dished pistons and pressed rods....biggest difference between the lq4/9 is the flat top pistons and floating rods on the lq9 and pressed wrist pins and dished pistons on the lq4... Blocks and cranks are same heads were mostly 317s....though inthink there was another casting number they may have used...
Old Feb 26, 2016 | 02:21 AM
Formerly ScreamingL
Also forgetting that in late 04 the lq4 recieved same rods as the lq9 and other motors did
The difference during that era was .5 in cr by the piston
All iron 01-07 gen3 6.0 had 317s..99-00 had iron heads and weaker motors that had a odd ball crank
Old Feb 26, 2016 | 12:06 PM
Wolftrk99's Avatar
The early crank was designed specifically for the 4l80e to bolt to....
Old Feb 26, 2016 | 06:30 PM
1FastBrick's Avatar
Custm2500's Rude Friend
There was an 035 replacement head floating around for the 317's
Grippy had a set on his old ride.
TwiZtedZ71
Mar 15, 2016 06:41 PM
Turbo6.0
Feb 19, 2016 03:17 PM
TwistedBigRig
Feb 14, 2016 01:27 AM
02AWDAWSDenali
Jan 30, 2016 09:48 PM
trappercrk
Jan 26, 2016 08:48 PM
