03-06 complete engine swapped to 2011 Silverado??
Old Feb 19, 2016 | 01:16 PM
Turbo6.0's Avatar
Default 03-06 complete engine swapped to 2011 Silverado??
I got a great lead on a 2011 Silverado crew cab fully loaded. It had the engine, engine wire harness, trans, radiator, grill, headlights, and hood stripped out of it.
I have a complete drop out motor and 4l60e with wire harness from a 2006 Silverado 1500. Can I use this in the 2011 or is it not worth the hassle?
Thanks!
Old Feb 19, 2016 | 02:58 PM
Lil brother PI's Avatar
Friend of mine did it and had allot of issues not sure why....best bet is get one newer and be done with it
Old Feb 19, 2016 | 03:10 PM
FFDP's Avatar
The 2011 PCM needs to be used, they have a PCM and TCM. The 4L60e will not have that. And all the other BCM functions that go along with that wire harness.
The motor in the 2011 has a different crank trigger compared to the older motor, different cam sensor locations. Wire harness is completely different between the two, you need one for that truck.
You are best off getting a GEN 4 motor, matching transmission (6L80e), wire harness and computer. Then see if the dealership can reprogram everything for you to match up.
Old Feb 19, 2016 | 03:17 PM
Turbo6.0's Avatar
Gotcha, thanks for the info! Might just buy it and part it out. I'll keep y'all posted..... Thanks again for the fast response lil brother and FFDP!
jscherbs
Feb 16, 2016 05:25 AM
Chaney3000
Feb 4, 2016 07:00 PM
02AWDAWSDenali
Jan 30, 2016 09:48 PM
Prolong
Jan 25, 2016 12:13 PM
