MULTIMEDIA (truck related) Post your Truck pictures and videos (PG-13)
So Close to 10's Guys and Gals (Vid)
Old Jun 25, 2011 | 01:59 AM
Swerve7rpm2000's Avatar
Default So Close to 10's Guys and Gals (Vid)
Man was this a good night, first night on the transbrake, bumped the boost up to 15 psi, 116 octane, 15-16 degrees of timing, but nailing the limiter with shifting problems that never seem to go away! I never got outta 2nd gear on this pass so i pretty much coasted after the 1/8 mile...... Right side of timeslip look at the 1/8 mph and 1/4 mph haha Pisses me off!
http://www.youtube.com/watch?v=m96-6ZKde3g
Old Jun 25, 2011 | 02:04 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Get that beast sorted out! Looks like an animal!
Old Jun 25, 2011 | 09:36 AM
montecarloss's Avatar
LS ADDICT/BUILDER
very nice, was that on drag radial?
Old Jun 25, 2011 | 09:40 AM
Wilde Racing's Avatar
How do I change this text
SHIFT... lol What do you think is the problem?
Old Jun 25, 2011 | 10:59 AM
Llaverito's Avatar
very nice, cant wait to see 20+ psi
Old Jun 25, 2011 | 11:10 AM
[QUOTE=Wilde Racing;4723883]SHIFT... lol What do you think is the problem?[/QUOTE
Man tbh I dunno at this point, when I left brake boosting the first pass it made all shifts fine this is when the shift lever was in drive only, when I use trans brake I have to take off in 1st gear and upshift 3 times asap then let the computer control it but it wouldn't go into 3rd.... It also seemed after 5,000 rpms boost started dropping a bit so I might lower the shift rpms to keep the motor in it's sweet spot, I'm gonna road test the tranny today! Thanks guys
Old Jun 25, 2011 | 11:12 AM
Yes sir and barely using the tires! This track just underwent surgery in the past month and is dead hooking for me off the line, about 15 psi tire pressure at line
Old Jun 25, 2011 | 11:36 AM
custm2500's Avatar
Ph.D. in HUBRIS
Looks good!
DO you have a blow off? I am not a turbo expert but the "chuging" after your burn out makes me think you don't have one. That will help a tiny bit keeping boost through shifts.
Old Jun 25, 2011 | 12:08 PM
tarinitup's Avatar
9 Second Truck Club
Great improvement from last time. Once you get it sorted out you will hit 10s.
Old Jun 25, 2011 | 12:10 PM
Bigschwerm's Avatar
Runs strong!
