Midsize & Compact Trucks Suspension | Wheels | Tires | Drivetrain |Engine | Body
"Project LS10"
Old Jun 5, 2013 | 07:01 PM
  #261
LSGUNSS's Avatar
formerly 2000blackcamaross (6-25-2013)
I finally got the axles back from the machine shop. I really like the work done and he will be making the drive shaft for me. I used the stock axles but I did use ARP studs, New solid rotors, and new brake pads. I installed it all tonight but I still need to get one more U-Bolt (one of the ones I had made was 1" short), modify the E-brake ends and bleed the brakes.
Pics:
The re-drilled rotors. He drilled them 1/2" so there isn't the factory slop in them.
You can see where the hub had to be milled down to 70mm so I could run Corvette wheels. The shoulder had to be left on for a rotor locator.
With the rotor on
Everything in the truck
I painted the tags the same as the rear and installed them on each side for looks
Wheel to spring spacing without the 1/4" spacer
Old Jun 6, 2013 | 08:01 PM
  #262
LSGUNSS's Avatar
She is on the ground. Right now it has the old gasser look to it. lol I'm building traction bars for it real soon, this weekend prob. I will post up about that and I'm thinking about making a how to thread on it. We will see how they turn out first.
Old Jun 7, 2013 | 09:08 PM
  #263
LSGUNSS's Avatar
I started working on the traction bars while I am waiting on the driveshaft to be made.
Here is what I started with.
Then I cut the top link in half.
I cut part of some square tubing so I could use them to adjust the traction bars.
Then welded them in the middle (just spot welded)
I took the top link and screwed it all the way in and then drilled holes to fill weld to make the ends stronger on the rod. Right now I am just spot welding everything and I will weld all around the ends.
That's all I had time for tonight. More to come tomorrow... I hope.
Old Jun 11, 2013 | 08:15 PM
  #264
LSGUNSS's Avatar
Just a few pic's of what I did in the 97* shop...
The rear mount without a hole for the bolt
Front mount without the hole
The square tube welded on so I can pre-load and adjust the springs
Some mock up pics
Lowest point of the bar in front of the rear wheel
The height of the front mount
Old Jun 12, 2013 | 06:00 PM
  #265
Gonoma's Avatar
Looks like 2.2 truck...sleeper I like it lol
Old Jun 12, 2013 | 08:07 PM
  #266
LSGUNSS's Avatar
Thanks. I was going for a "Stockish" look I am hoping the traction bars don't take away from that.
Old Jun 12, 2013 | 08:12 PM
  #267
2000chevysilverado's Avatar
Im ready to see this on the streets gonna be nasty
Old Jun 13, 2013 | 08:33 PM
  #268
LSGUNSS's Avatar
Thanks man. I'm ready for this thing to be out and about myself!
Old Jun 13, 2013 | 08:34 PM
  #269
LSGUNSS's Avatar
I received my 2" drop springs yesterday but I haven't had time to work on the truck because of hay. I plan on working on it tomorrow after work. I am hoping to get the drive shaft, put it in, put the springs in, work on the traction bars and maybe get the pillar pod installed. Wish me luck
Old Jun 16, 2013 | 03:39 PM
  #270
LSGUNSS's Avatar
This is what I got done this weekend. I just made two gauge pods
