Midsize & Compact Trucks Suspension | Wheels | Tires | Drivetrain |Engine | Body
"Project LS10"
Old Oct 24, 2012 | 03:39 PM
  #141
LSGUNSS's Avatar
formerly 2000blackcamaross (6-25-2013)
Look what I found...
Radiators - Chevy - S10 Trucks - Engineered Cooling Products - (Powered by CubeCart)
IMO it is worth buying the radiator with the fans because there fitted and you don't need to mess with mounting and making a shroud. I wish I would have saw this but I'm happy with mine.
and fans...
Flex-a-lite 490 - Flex-a-lite X-Treme S-Blade Electric Fans - Overview - SummitRacing.com
I was wrong on it being summit or jegs brand.
Old Oct 24, 2012 | 05:58 PM
  #142
TXsilverado's Avatar
and fans...
you are the M.F.ing MAN! just saved me alot of money. i may do the double adjustable rear coil overs now lol.
Old Oct 24, 2012 | 08:03 PM
  #143
LSGUNSS's Avatar
Thank you sir.
I am working on the hoses but failed tonight to get it done. I will have to make another parts store run. I'm sure my Duramax could just drive it's self there by now. lol
P.S. somethings that **** me off... the only way to buy a new V6 throttle cable is to go to the dealer and get raped... the same with a LS1/6 intake throttle bracket (I happen to find a guy after 3-4 months of keeping my eyes open)...there isn't a parts store closer...I guess i'm done
Old Oct 24, 2012 | 08:26 PM
  #144
RS/SS 4.8's Avatar
10 Second Truck Club
Are you planing on a swap?
Maybe
94 S10 4 door blazer.
Old Oct 26, 2012 | 10:35 PM
  #145
LSGUNSS's Avatar
Did some small stuff on the truck today. I took the grinder to the bottom of the intake to make it smooth. This will allow the crossover tubes to fit under the intake without problems. I also took a pic of the hose I am using for the lower hose and the part number.
Old Oct 31, 2012 | 07:40 PM
  #146
LSGUNSS's Avatar
Today I almost finished up the fuel system. I already installed the Aeromotive 340 Stealth so now it was time for the Corvette fuel filter and all the fittings. Everything went smooth and the filter is in but I still have to cut the steel braided line that I have running to the fuel rail.
Old Nov 1, 2012 | 08:07 PM
  #147
LSGUNSS's Avatar
Found a Upper radiator hose!!!! I also did some other small stuff that you may or may not be able to tell in the pics like heater hoses. Enjoy
Old Nov 1, 2012 | 08:19 PM
  #148
RS/SS 4.8's Avatar
Super nice. Ur makin me wanna scrap my 91 camaro 5.3 swap to start my s10 swap.
Old Nov 2, 2012 | 01:39 PM
  #149
looks like it's ready to start. what's the hold up?
Old Nov 2, 2012 | 04:15 PM
  #150
LSGUNSS's Avatar
Wiring harness, fluids, belt, drive shaft, camaro belt tensioner, and trans lines to cooler.
I'm shooting for all of this to be done (including adding the LSD) in two weeks when I am expecting the wiring harness to be here.
