Yet Another Head Thread
OK, so I just picked up a 5.3 block that has been bored to 3.898 as the start of my 247/5.7 build for my Suburban
Seller is throwing in a set of 862 heads.
I also came across a set of 241 heads.
I know everyone talks about the vaunted 243/799 heads, so what are your thoughts on using one of the other two sets?
I believe the 241's use the same 2" intake valves as the 243's.
The 241's combustion chambers are +/- 2cc larger while the intake runners and exhaust ports are slightly shorter/smaller.
All of this "matters" the big time LSx guys building them for F-bodies and Vettes looking for HUGE how numbers and top end.
I question how much they would make a difference that would make in my Suburban build.
Keep in mind, the Burb is a DD and part time tow rig.
I'll be running stock crank, stock rods, flat top pistons, Comp trunion upgrade, Blue LS6 springs, stock rockers, new 7.4" pushrods, new Delphi lifters, a cam in the 208-214/208-214, 108-114 LSA range, shorty headers, Flex Fuel injectors, and likely a TBSS intake.
Run the 862s. More power was made, even on a 6.0. Everyone’s gonna hoop n holler about compression ratio but I just don’t think the velocity is high enough with the larger runner. Cut the 862 .030 and send it. Also, get at least a 24” breaker bar or ratchet for the head bolts. That last 90 degrees is a real bitch.
Don't the 862's have an even smaller CC and also the smaller intake valves? I don't have the comparison info in front of me.
I'm on my phone, I'm exhausted, it's been a long day between work, hurricane prep and finishing putting the front end of the POS back together.
Work comes early at 0400 again tomorrow.
Look forward to more feedback .
CMC
Steve Bryant
24
Oct 13, 2008 03:53 PM
BLACKND
Sep 13, 2005 10:33 AM
