Yellow LS6 Springs?
Old Apr 25, 2009 | 11:47 PM
jake 03's Avatar
Originally Posted by jonnyboy
Before I get flamed, I've searched. I know the yellow ls6 springs are supposed to be good for almost .580 and have around 294# seat pressure. That said, would they be a good spring for 220/224 .575" lift on 112 LSA? That lift is cutting it close. Thanks.
I used the yellow ls6 springs with 3 different comp cams,one of which was the same as what you have,and put 25000 miles those springs and never had a problem,even with 6700 rpm shift points.I think the yellow springs would do you just fine IMO.
Old Apr 26, 2009 | 12:04 AM
Thumbs up
I am using LS6 springs with ASA cam low lift but shift at 6700 6600 and 6300 no problomes mods in sig!
Old Apr 26, 2009 | 07:08 PM
Same here.
running LS6 yellows.
Mild cam 206/212 w/ .554/.558 lift
Old Apr 27, 2009 | 09:21 AM
jonnyboy's Avatar
thanks guys. due to the comments and pics, i believe i'm either going with patriot dual springs or some trick flow dual springs. looks like all you guys with ls6 springs are running lower lift than my cam.
1989k1500
Nov 2, 2015 05:16 AM
vipergtrdj
Sep 11, 2015 05:52 PM
PDPERFORMANCE
Sep 8, 2015 11:01 AM
screaminian47
Sep 7, 2015 08:20 PM
lxcoupe
Sep 2, 2015 12:58 AM
