Yellow LS6 Springs?
Old Apr 24, 2009 | 04:51 PM
jonnyboy's Avatar
Default Yellow LS6 Springs?
Before I get flamed, I've searched. I know the yellow ls6 springs are supposed to be good for almost .580 and have around 294# seat pressure. That said, would they be a good spring for 220/224 .575" lift on 112 LSA? That lift is cutting it close. Thanks.
Old Apr 24, 2009 | 06:45 PM
Silver-Dollar's Avatar
Personally, I would upgrade to a higher rated spring. .005" is not enough comfort room for me.
Old Apr 24, 2009 | 07:34 PM
budhayes3's Avatar
PT's Slowest Truck
Yea, that's cutting it close, not to mention the ramp rates of the lobes make a difference also. If the lobes are very aggressive, you're going to want more seat pressure. The LS6 springs have 90# of closed seat pressure as opposed to 130# of the popular PAC springs (can't remember the part number off the top of my head right now...)
Old Apr 24, 2009 | 08:02 PM
charcold-bowtie's Avatar
I run them on the boosted truck with teh ls6 cam? no problems thus far.
Old Apr 24, 2009 | 10:14 PM
budhayes3's Avatar
PT's Slowest Truck
LS6 cam = LS6 springs, makes perfect sense, even boosted . I'm running LS6 springs with my current baby cam, and I will be using them in my LQ9 also, which I have a Vinci Trucker cam for (216/224 .551/.551 115).
Old Apr 24, 2009 | 11:26 PM
53RUSSELL's Avatar
I'm running Yellow LS6 Springs on a 216/218 .563/.563 114lsa and the truck has 8lb of boost.
Old Apr 25, 2009 | 04:56 AM
jonnyboy's Avatar
thanks, guys! so it sounds like i need to go ahead and get some comp 918 springs.
Old Apr 25, 2009 | 04:59 AM
GMCtrk's Avatar
go with pac 1218
Old Apr 25, 2009 | 08:00 AM
RADO_4U2NV's Avatar
I would not waste my money on comp springs. Spend the extra 50 or so bucks and get some patriot duals. Then If you ever go to a bigger cam you have springs good to .650 lift. Here are my comp springs. This Is why I will never put another comp product in my truck. Oh and the lift of the cam was only .574 int and .572 ext.
Old Apr 25, 2009 | 07:22 PM
budhayes3's Avatar
PT's Slowest Truck
Nooooo! Look at the pics above, that is the new, updated "silver" Comp 918's in that pic. PAC's FTW!
