who builds engines these days?
Old Oct 20, 2007 | 09:42 PM
  #31
TurboGibbs's Avatar
On the subject of old vs new I will say that there IS NOT much difference in the basic mechanics in tolerances, machining and clearences. If you try to power hone a gen3 block just like you would a gen1 without caution an open mind to cyl growth with heat in the machining process etc.... you will have problems with the machining. As far as bearing clearances, they are really no different than a gen 1 that i've seen and built. They use the same rod brgs and 98% of the after market forged rods are gen1's that have pistons made with the gen1 .927 wrist pin (gen3 come with .945").
There can always be a weird or unforseen issues with any engine build, the only difference is how the builder handles the issue. IMO if an old school reputable engine shop sends an engine out with improper clearences in an engine then they are probably not really a good shop. But there are always many sides to any story.
Just my $.02
Old Oct 21, 2007 | 12:16 PM
  #32
Ross @ EDO's Avatar
FormerVendor
If I was to have an engine built, I would either go with Texas-Speed or have Jason that builds them for Thunder build me one. This is only becuase I have seen the outcome and longevity of motors built by these two.
Old Oct 24, 2007 | 03:10 AM
  #33
Spoolin's Avatar
GFYS and STFU
... IMO how you judge a shop is how they stand behind their product and it seems they are doing just that.
Old Oct 24, 2007 | 08:36 AM
  #34
Nickens Racing is building mine. They do everything in house.
Old Oct 24, 2007 | 09:57 AM
  #35
Holty's Avatar
Notorious BIG
I have no input for this thread. I am subscribing to it for future reference.
Old Oct 24, 2007 | 10:37 AM
  #36
zippy's Avatar
If I were doing an LSX block I'd go to W2W, Synergy, or WCCH. W2W would be my first pick, but not because the others aren't also top notch at their job.
Old Oct 24, 2007 | 11:54 AM
  #37
DamnYankee's Avatar
formerly Moze (2/24/2012)
HKE will be doing mine when the time comes. TRT in Arlington uses them and Erik (at HKE) knows his stuff from what I hear.
link (am I allowed?)
Old Oct 24, 2007 | 02:28 PM
  #38
Spoolin's Avatar
GFYS and STFU
I hope that whatever future reference your speaking of is not gonna be as big a job as the one you just previously endured!!! A simple engine swap would be like a walk in the park for you!
Old Oct 24, 2007 | 03:57 PM
  #39
Holty's Avatar
Notorious BIG
yeah tell me about it! Although, i can't take all the credit, i couldn't have done it (as quickly anyways) without wkdivr and quik. But your right, engine swap should be cake compared to what i went through after the wreck. It was a ton of work but i learned alot along the way for sure. One of the things i learned is that i never want to replace a frame again on any vehicle.
Old Oct 25, 2007 | 02:57 PM
  #40
maddboost's Avatar
I would recommend W2W they may be more than some other shops but they do quality work. Plus which ever shop you have do your motor make sure they have already done a LSX block before because I remember Kurt on tech posting that they needed special girdles or plates for honing the LSX blocks compared to normal LS1/LS6 engines. All the engine building is done by Billy Briggs just call and ask for him.
ARC
57
Feb 21, 2022 10:54 AM
thunder550
Oct 8, 2015 04:53 PM
USMCvet0311
Aug 14, 2015 10:28 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
4B11T
Jul 13, 2015 03:48 PM
