What head
Old Jul 22, 2012 | 03:54 PM
Blacksrt403's Avatar
Default What head
I'm gonna have heads off what head is a direct bolt on that can give me a good boost without getting too crazy. I have an lq9 with mp112 and installing Lep blower cam specs 224/230 with 612 lift and 116 lsa. Thanks Alex
Old Jul 22, 2012 | 03:57 PM
charcoal03silvy's Avatar
worked over 243 heads or l92 top end swap... unless you want to go aftermarket that is..
Old Jul 22, 2012 | 04:42 PM
Would I need anything other than the head itself, I have patriot gold springs that's all
Old Jul 22, 2012 | 04:45 PM
not for 243's.. l92 top end requires a few things
although 243's drop compression so you'll need to have them milled
Old Jul 22, 2012 | 05:31 PM
ForcedTQ's Avatar
Lightbulb
243's wouldn't drop compression, they would raise compression, it'd be 10.9:1 like an LS2 if he had stock LQ9 flat top pistons.
Might want to talk to WCCH and look into a port/valve job/combustion chamber re-size (down a little to raise compression a little, but not too much to cause problems with detonation, and enhance squish area.) See what he recommends for your 317's, those were just my ideas.
Old Jul 22, 2012 | 05:33 PM
wasn't thinking lq9.. they drop compression on 5.3 ad 4.8 though
Old Jul 23, 2012 | 09:43 PM
Well ordered tsp stage 1 317 heads and I have patriot springs lets see how she does
Old Jul 30, 2012 | 05:53 PM
Sales3@Texas-Speed's Avatar
Truck Sponsor
Excellent choice, they should work great with your setup!
Old Jul 30, 2012 | 06:43 PM
TXsilverado's Avatar
dont do a ported 243 head....send your 317 out for some work since you have a supercharger. they will flow just as good as the 243 and keep your compression where you need it.
Old Jul 30, 2012 | 07:04 PM
Thanks for input guys , it's appreciated
