What can I expect with this cam?
Old Nov 26, 2011 | 03:45 PM
bagged7104SS's Avatar
Default What can I expect with this cam?
I just bought a new cam and was wondering how it will act with my mods? Pat G. specked it- Specs 218/228.563" 116LSA+2 advance. I also got some TEA .660 dual springs and 7.400 pushrods. My stock trans finally gave up after 100k miles 70k blower miles. I ordered a new trans from Performabuilt level 2 with a 2800 billet torque converter. I am going to pulley down to a 2.8 and am contemplating meth because I live in the valley where its always hot just about. This is my DD and was wondering if it will have nice driving manners.
Old Nov 26, 2011 | 05:59 PM
swift700's Avatar
Sounds like a great cam for a Radixed 6.0.
Old Nov 26, 2011 | 06:08 PM
old motorhead's Avatar
You'll like that cam. Pat G. doesn't miss too often if at all. I have one just slightly smaller and one just a little bigger. Both under TVS2300's. It should idle just slightly rougher than stock. Any softness on the bottom end will be picked up by the MP122. Rockin' a 2.8 pulley, you'll be able to get into boost at the blink of an eye. With a good tune, you should have near perfect manners.
Old Nov 27, 2011 | 12:03 AM
Vortec350ss's Avatar
That cam should be awesome with your blower. I would think you would see a huge improvement over stock, even more so than an NA motor like mine. I can't imagine you wouldnt love it.
Old Dec 1, 2011 | 11:09 AM
Yayyyyyyyy!!! Now I can't wait to get it installed and tuned. Thanks guys.
Old Dec 1, 2011 | 11:47 AM
1SlowHoe's Avatar
Destroyer of Transmissions
Check with Pat again on the pushrod length. If he spec'd it out from his usual vender (EPS), the lobed are slightly different. My PatG cam required 7.425" push rods.
Old Dec 1, 2011 | 12:32 PM
Don't believe those are EPS's proprietary lobes. Probably Comp Cams lobes. The EPS stuff has higher lift.
Old Dec 1, 2011 | 12:44 PM
grey matter 04's Avatar
13 Second Truck Club
eps is usually .598 0r .600
that .563 sounds like comp maybe xer lobe? which explains the 7.4 pushrods
Old Dec 1, 2011 | 03:59 PM
It's a Comp Cam. My fuel system should handle this, yes?
Old Dec 1, 2011 | 05:58 PM
If everything is "right", it should. If the pump gets a little weak or the sock gets a little dirty, you'll be in trouble. Keep an eye on the fuel pressure/afr's. I had almost the exact same rig as you're running. Truck went a little lean....lean condition provided me with an "opportunity" to forge the motor.
fastjweb
Aug 15, 2015 10:47 AM
black03rcsb
13
Aug 13, 2015 04:05 PM
OLD BULL
Aug 1, 2015 05:00 PM
