truck rattles valves at wot?? even with good gas!
Old Mar 10, 2007 | 11:01 AM
nosfedgta's Avatar
9 Second Club
Default truck rattles valves at wot?? even with good gas!
I dont know what is wrong with my truck. its a 02 ecsb with a 5.3 Only mods are a custom made 4in cold air kit. At wide open throttle it will rattle the hell out of the valves no matter what kind of gas I have in it. I just dont understand it. I have runn diff kinds of gas, I have even tried octane boost. nothing works. the other thing i dont get is why is the computer not pulling any timing out when this happens???? I tried running it at a local 1/8th mile track and it only ran a 10.35 with then all of a sudden it ran 10.15@70mph then it went right back to a 10.38 at 68...
Its just wierd that it is doing this... any help ?
Old Mar 10, 2007 | 11:27 AM
'89ChevyMadneSS's Avatar
that one has an easy fix. trurn your stereo up every time before you punch it
ive got a dead lifter that causes about the same thing, only with one, but it is the LOUDEST valvetrain noise i have ever heard. but imho its not worth fixing on the tbi when ive got a 6.0 on the stand so i just crank up the tunes!
Old Mar 13, 2007 | 07:51 PM
MCDiver's Avatar
The noise may go away if you have a custom tune done. If it is a spark knock, a tune will get rid of it.
Old Mar 13, 2007 | 09:06 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Loose rocker arm(s)?
Old Mar 14, 2007 | 02:03 PM
nosfedgta's Avatar
9 Second Club
yeah I though A tune would help.. I am wondering if the cold air is sucking so much air " 4in cold air" that it may be causing some issues.....
Old Mar 14, 2007 | 02:06 PM
Quik's Avatar
5 year bitches!
you might have an leak afte the maf. if you suck in fresh air that isnt calibrated it will caue the motor to ping
Old Mar 14, 2007 | 02:19 PM
Jokeman's Avatar
I get the same thing. Sounds like the motor is filled with marbles at WOT.
Old Mar 14, 2007 | 03:09 PM
WorkTruc's Avatar
Try changing fuel filter if you have an 99-03 model.You would be suprised but I have seen 2 trucks ping WOT AND fuel filter cured problem,no more lean condition.
Old Mar 14, 2007 | 05:47 PM
Mighty Wings's Avatar
My buddies Vette was doing the same thing too. He took it to the dealership and they used "top engine cleaner". They told him it was carbon build up in the engine. Anyway, it went away afterwards. I think they poured it into the spark plug holes (plugs out of course) and let it sit over night.
The_W
Oct 28, 2015 09:00 PM
kyle's v
Oct 4, 2015 12:37 PM
black6spdz
Jul 16, 2015 01:32 AM
cwylie
Jul 7, 2015 11:42 AM
Nimoryan
Jul 5, 2015 03:50 PM
