tips for better compression
Old Jun 18, 2006 | 10:33 PM
Default tips for better compression
with all the mods considered in my sig, including those ones being installed, wha t could i do to net some better compression ratios.... also what are the benefits of higher compression?
Old Jun 19, 2006 | 12:48 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
thinner head gaskets/shaved heads you need good heads along with a higher CR to make good use of the cam you trying to install
Old Jun 19, 2006 | 02:59 AM
Quik's Avatar
5 year bitches!
if you really wanted to do the effort put 4.8 pistons in your motor so you would have flat tops and basically a 5.3 HO, put you around 10.1 that would start you off with some decent gains on a cam
Old Jun 19, 2006 | 03:51 AM
yea i know i need a good set of heads and that would help me out pretty good, only thing is a dont have 1500-2000$ laying around to have a decent pair....where can you pick up thin gaskets? would the 4.8 pistons do any damage? and since it is a smaller bore in the engine are the pistons smaller or would i just need a biger piston ring?
Old Jun 19, 2006 | 04:16 AM
NoChrome's Avatar
The bore dosnt change, its the stroke of the crank thats different between the 5.3 and the 4.8
Old Jun 19, 2006 | 06:18 AM
TURBHOE's Avatar
look into the l92 heads for cheap swap. sdpc is starting to carry them now.
Old Jun 19, 2006 | 05:27 PM
FarmerBeau's Avatar
Sexy Party Mod
i have heard that the 4.8 l wrist pins are in different positions that the 5.3. Dont know how that would affect the clearances? Just a thought.
Miguel199
Oct 16, 2015 08:04 PM
Velocity1
Oct 2, 2015 08:01 AM
old motorhead
Sep 29, 2015 08:22 PM
11MPG
Sep 10, 2015 08:34 PM
