tips for better compression
with all the mods considered in my sig, including those ones being installed, wha t could i do to net some better compression ratios.... also what are the benefits of higher compression?
if you really wanted to do the effort put 4.8 pistons in your motor so you would have flat tops and basically a 5.3 HO, put you around 10.1 that would start you off with some decent gains on a cam
yea i know i need a good set of heads and that would help me out pretty good, only thing is a dont have 1500-2000$ laying around to have a decent pair....where can you pick up thin gaskets? would the 4.8 pistons do any damage? and since it is a smaller bore in the engine are the pistons smaller or would i just need a biger piston ring?
