tick tick tick tick
Old Jan 11, 2010 | 06:58 PM
TURBHOE's Avatar
Default tick tick tick tick
can some one help me figure out what the tick is. it comes it goes and it annoys the crap out of me.
i have had this tick for about a year now. maybe a bit less. when you first start it there is no real tick. about 2-3seconds later it starts. then as it idles the tick comes and goes. like tick tick tick tick ..................tick tick tick.......
its on the passenger side frontish. when its cold and i drive it the tick gets louder and faster with rpm and load. but when warm its not too bad. i have replaced lifters and cam and springs. when i first put in the cam the tick went away for a while but a month after it came back. but even when it was "gone" it was still kinda there. just quieter it seemed.
Old Jan 11, 2010 | 07:04 PM
GMCtrk's Avatar
I'm pretty sure it's your log. Headers sound like absolute ****.
Old Jan 11, 2010 | 07:05 PM
viciousknid's Avatar
Where's the Beef?
What exhaust gaskets are you using?
Old Jan 11, 2010 | 07:27 PM
TURBHOE's Avatar
stock gasket. when i replaced the cam i DID weld up a few cracks on the manifold. i thought maybe that what it was too. but i checked it for cracks before my trip and couldn't see any. then again i was using a mirror and log was installed.
Old Jan 11, 2010 | 07:35 PM
GMCtrk's Avatar
It has nothing to do with the crack, it's the thinness of the stainless steel that amplifies and transmits the valvetrain noise. Have you had headers on your tahoe before? When I had headers it sounded like I had a rod knocking if you got near the passenger wheel well. I put the stock thick iron manifolds back on and the noise was gone.
Old Jan 11, 2010 | 07:52 PM
EVILGMC's Avatar
if it was any further back id say flexplate...
Old Jan 11, 2010 | 07:53 PM
TURBHOE's Avatar
but when i first installed the turbo it never made a sound. it wasn't till about a years later that it started. and when i welded up the crack it went away. there was still the valve racket but not the tap tap tap. here is a vid from when it first started. http://user.streetfire.net/video/tur...tap_636916.htm
Old Jan 11, 2010 | 07:59 PM
TURBHOE's Avatar
i thought that too but when i installed the trans 2 weeks ago i looked it over and didn't see anything. unless its in the bolts and not visible when not running.
Old Jan 11, 2010 | 08:02 PM
GMCtrk's Avatar
Maybe it has cracked again in an area that you can't see with it installed.
Old Jan 11, 2010 | 08:11 PM
TURBHOE's Avatar
when it loads up here is another video while cold and fast idle, http://user.streetfire.net/video/tap...ise_728653.htm
