Tfs heads pushrods now lots of valvetrain noise
Old Sep 10, 2014 | 08:42 PM
  #21
lukn4trbl355's Avatar
That's the route I'll take then also are the shims for the pedestals strictly for the more than one turn deal yt advertises or is it used for wipe pattern?
Old Sep 12, 2014 | 05:35 PM
  #22
really need some insight guys this whole yella terra instruction deal compared to the comp istructions is making my brain hurt.
pushrod length is set at 7.6 and came out to 1 and 3/4 turns of preload so roughly 90-94 thou...i know this is stock lifter preload on ls1s but this seems way too much. in the YT instructions they strictly say if there is more than 1 turn to run a shim, the question is with the shim will i be close to one full turn/ still within spec?
Old Sep 12, 2014 | 05:41 PM
  #23
TXsilverado's Avatar
LMAO you're not listening at all. the 1 3/4 turn method is a crap shoot. dont post back until you have checked with a pushrod length checker. the ONLY way to check should be with a pushrod length checker.
can you get a video of this noisey valvetrain?
Old Sep 12, 2014 | 05:59 PM
  #24
Tx I'm outside doing that lol 7.6 on the checker is 1.75 turns 7.550 is 1 full turn and the video is a few posts back
Old Sep 12, 2014 | 06:32 PM
  #25
My bad for not clarifying that earlier lol I took my time with checking I'm just debating on which route id rather go so that I can order the pushrods before 7 so they arrive tomarrow
Old Sep 13, 2014 | 10:23 AM
  #26
So what length was the checker at zero lash?
Old Sep 13, 2014 | 10:55 AM
  #27
I was told that way comes up with the same measurement as extended and tqing down. I could do it the way your describing too if need be just to check. Checker was 6.8 and 15 turns for .47 preload and the 7.6 offered 70 thou.
Old Sep 13, 2014 | 11:09 AM
  #28
If I remember right zero lash should be 14 turns
Old Sep 13, 2014 | 11:42 AM
  #29
Extend the pushrod to zero lash then add the desired preload. Thats the length pushrod you want.
Old Sep 13, 2014 | 12:05 PM
  #30
Alright thank you sir that does come out to a 7.550 then. I just hope this quiets the valve train up a bit
greedygenius
Sep 3, 2015 06:51 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
lxcoupe
Jul 30, 2015 02:42 PM
Ammadien
Jul 22, 2015 08:50 PM
GRRR65GTO
Jul 10, 2015 08:27 PM
