Some help with piston selection
Old Dec 17, 2010 | 09:25 PM
KDavis04ss's Avatar
Default Some help with piston selection
Im doing a 4.005 bore l76. I want to run a dish piston that will get me around 10:5-1 to 11:0-1 with my PRC 2.5 5.3 heads. I believe they are 62CCs. But I want to be able to replace these heads with some 70ishcc heads down the road for boost. Assuming around 9:5-1 is what Il want to shoot for. So basically I want to run high compression N/A for a little while to get the truck going then Switch to lower compression for boost later on with the same short block. Can it be done?
Old Dec 17, 2010 | 10:25 PM
BigKID's Avatar
With stock head gaskets and deck height, I calculate with a 6cc piston:
62cc heads = 10.62:1
70cc heads = 9.72:1
72cc heads = 9.52:1
an 8cc piston:
62cc heads = 10.38:1
70cc heads = 9.52:1
72cc heads = 9.33:1
Old Dec 17, 2010 | 10:31 PM
KDavis04ss's Avatar
your the man, Thanks
Old Dec 18, 2010 | 12:41 PM
KDavis04ss's Avatar
Whats the best 4.005 or 4.030 piston for a stock stroke? Everyone I find is for a 4.000 crank. Im staying with the stock 3.622
Old Dec 18, 2010 | 12:43 PM
Phantom's Avatar
11 Second Club
using stock rod or 6.125?
Old Dec 18, 2010 | 12:51 PM
KDavis04ss's Avatar
callies 6.125
Old Dec 19, 2010 | 02:33 PM
BigKID's Avatar
I am using Wiesco -11cc 4.030 pistons in mine on 6.125 K1 rods and stock crank.
Old Dec 19, 2010 | 06:33 PM
KDavis04ss's Avatar
yeah the k1's are nice
lukn4trbl355
Oct 21, 2015 11:19 PM
turbo6c3
Oct 5, 2015 06:11 PM
Wolftrk99
Oct 2, 2015 08:17 AM
StrokeTheLS
Sep 29, 2015 08:33 PM
