Some help with piston selection
Im doing a 4.005 bore l76. I want to run a dish piston that will get me around 10:5-1 to 11:0-1 with my PRC 2.5 5.3 heads. I believe they are 62CCs. But I want to be able to replace these heads with some 70ishcc heads down the road for boost. Assuming around 9:5-1 is what Il want to shoot for. So basically I want to run high compression N/A for a little while to get the truck going then Switch to lower compression for boost later on with the same short block. Can it be done?
With stock head gaskets and deck height, I calculate with a 6cc piston:
62cc heads = 10.62:1
70cc heads = 9.72:1
72cc heads = 9.52:1
an 8cc piston:
62cc heads = 10.38:1
70cc heads = 9.52:1
72cc heads = 9.33:1
70cc heads = 9.72:1
72cc heads = 9.52:1
an 8cc piston:
70cc heads = 9.52:1
72cc heads = 9.33:1
lukn4trbl355
Oct 21, 2015 11:19 PM
StrokeTheLS
Sep 29, 2015 08:33 PM
